1Back to top Go down   K100 will not start Empty K100 will not start Sun May 26, 2019 12:38 pm
cafe_racer_freak
cafe_racer_freak
Dear All,
my engine will not start again and the revolution counter will react without pushing the start button.
engine will get gas
sparks are new
starter is new
battery is new
all plugs are checked
My guess is the hall sensor or the watertemperature sensor
It would be very helpful if you could give me your ideas.
thanks a lot
Markus
2Back to top Go down   K100 will not start Empty Re: K100 will not start Sun May 26, 2019 5:08 pm
Watertempsensor; it will start, but not good.
Hallsensors; both must be broken, don't think so.
Check the sidestandswitch and the clutchswitch, and check if the neutrallamp is on, and zero on the dash.
Good start, good luck Smile
I just send you a personal message Wink
K100 will not start Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   K100 will not start Empty Re: K100 will not start Sun May 26, 2019 6:13 pm
What does this mean?
Have you tried pulling in the clutch when trying to start it?
4Back to top Go down   K100 will not start Empty Re: K100 will not start Sun May 26, 2019 6:44 pm
After failing to start are the spark plugs wet or dry??
5Back to top Go down   K100 will not start Empty Re: K100 will not start Mon May 27, 2019 4:40 am
cafe_racer_freak
cafe_racer_freak
MartinW wrote:After failing to start are the spark plugs wet or dry??
Good morning,
the sparks are wet.
Markus
6Back to top Go down   K100 will not start Empty Re: K100 will not start Mon May 27, 2019 4:42 am
cafe_racer_freak
cafe_racer_freak
Arlina wrote:Watertempsensor; it will start, but not good.
Hi Arlina,
my old Lady do not have the sidestandswitch. Neutral lamp is for sure on and it is ze.ro on the dash.
Markus
7Back to top Go down   K100 will not start Empty Re: K100 will not start Mon May 27, 2019 4:43 am
cafe_racer_freak
cafe_racer_freak
Hi Arlina,
my old Lady  Very Happy ( 1985 ) do not have the sidestandswitch. Neutral lamp is for sure on and it is ze.ro on the dash.
Markus
8Back to top Go down   K100 will not start Empty Re: K100 will not start Mon May 27, 2019 5:05 am
A faulty temperature sensor or connection can cause an over rich mixture and failure to start.
Removing the fuel pump fuse #6 or disconnecting at the four pin connector will allow the engine to start on the residual fuel in the combustion chamber. You will need to work the throttle and as the engine starts to die insert the fuse or reconnect the pump. Having an offsider helps. If it does start and run it will be running rough and you'll have to work the throttle. You will now have to either clean the connector or test and replace the temperature sensor.
9Back to top Go down   K100 will not start Empty Re: K100 will not start Fri May 31, 2019 8:02 am
cafe_racer_freak
cafe_racer_freak
Hey folks,
Allright , The Problem is solved.
I checked The Hallsensor and it is damaged.
One of The magnetic ports gives no signal.
Many thanks for your ideas and help.
Best regards
Markus
10Back to top Go down   K100 will not start Empty Re: K100 will not start Fri May 31, 2019 8:24 am
Good Smile
And now ride Very Happy
