1Back to top Go down   New Member from NC USA Empty New Member from NC USA Fri Dec 13, 2019 2:20 pm
cobaltc4s
cobaltc4s
Hi Everyone -
I've recently acquired a '93 K75 with 13K miles. It needs a bit of deferred maintenance, the previous owner put 2500 miles on it in 10 years. The tires are 16 years old but it seems everything else is original. Needs a few more rubber pieces here and there. I've had many air cooled bikes and a few K100's, this is my first K75.
I'm looking for a set of 'C' handlebars, a seat lock, and the 22 liter top case mount plate.
Does anyone know if they make radial tires for the  'Y' spoke wheels?
Does anyone have a recommendation for a throttle body/carb. balancing tool? The ones on Amazon get some pretty bad reviews.
2Back to top Go down   New Member from NC USA Empty Re: New Member from NC USA Fri Dec 13, 2019 3:20 pm
Carbtune Pro (what I use) gets a 4.6 on Amazon.  Since it's only three cylinders a TwinMax will work on a K75 pretty well. (And your R bikes.)
https://www.amazon.com/CARBTUNE-PRO-4-W-Pouch/dp/B018UTHGPE
Note that you can also buy direct with US shipping from the UK.  (Although the pound had a bit of a surge today based on election results.)
https://www.carbtune.com/
Continental Road Attack 3 - 10/80-18 front and 130/80-17 rear
3Back to top Go down   New Member from NC USA Empty Re: New Member from NC USA Fri Dec 13, 2019 4:15 pm
Welcome!!!  No need for expensive carb balancing machinery.  I've been using a couple bottles with some tubing and ATF for about five years now with excellent results.  Total coat was under $20, and I got to drink two bottles of overpriced iced tea.New Member from NC USA Thrott11
The surrounding enclosure isn't necessary.  It was the result of the intersection of some scrap wood and a couple bottles of malt beverage on a very boring winter evening.
4Back to top Go down   New Member from NC USA Empty Re: New Member from NC USA Mon Dec 16, 2019 11:23 am
playlikewedream
playlikewedream
Welcome
New Member from NC USA 177912
New Member from NC USA Ir-log10New Member from NC USA Ir-log10
;BMW; K1 1990 Laguna Blue and Yellow ;BMW;
;BMW; K1100RS 1997 Sedien Blue.;BMW;
Its not about the journey or the destination, it's about the friends you make on the way.
5Back to top Go down   New Member from NC USA Empty Re: New Member from NC USA Mon Dec 16, 2019 6:47 pm
brickrider2
brickrider2
Welcome from Idaho.
1996 K1100LT
6Back to top Go down   New Member from NC USA Empty Re: New Member from NC USA Mon Dec 16, 2019 11:32 pm
tinyspuds
tinyspuds
Welcome
