1Back to top Go down   New K owner, greetings!  Empty New K owner, greetings! Thu Nov 28, 2019 5:44 am
StandardK
StandardK
Hi everyone,
I have recently purchased my first K100 (usual ride RnineT Scrambler) that needed some love - she’s a “Madison Silver” 12/83 RS. It was destined to most likely become another cafe racer 😭
Hopefully I’ll be using some of the great info available on here😀
Regards
2Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 6:18 am
Welcome...I have a 12/83 K100RS too.
I never intended having one, its awesome and you will love it.
3Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 6:50 am
StandardK
StandardK
92KK 84WW Olaf wrote:Welcome...I have a 12/83 K100RS too.
Thanks! Looking forward to bonding with her.
My VIN: 0012116, not too many away from yours...😀👌
4Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 9:55 am
If you look on the cam cover on the left side you will see two small allen bolts ['engineering screws'] near no 4 cylinder, on on the upper [intake] cam cover and the other on the lower cover near where your toes rest...hopefully. My engine is 48/83 and yours should be close.
If you have these you will be more than a little surprised at the turn of speed.
Early ones like this have a few quirks...push button opening of the gas tank cap....brake calipers are different and you need early repair kits which are not easy to come by- worth laying in a set of the later ones.
There are comments on the use of unleaded gas in these engines so keep an eye out on that one. I haven't noticed anything amiss so fat but have only put 4k miles on it since I got it with 29k miles.
I broke the clutch cable a month ago and have a spare. One advice I always put a new clutch cable in a K when I get one, just hadn't done it with this one when it snapped but I had the spare and spare bikes so its still parked.
I have done a lot to it, brake pads, brake caliper repairs, both master cylinders, full service, tyres, wheels, some hoses, heat shield, indicator unit, K1100 stand assembly and still needs gear position indicator switch. Nothing I didn't figure on when I got it. PO had it in a boat shed for 17 years....first owner had it 18 years.
This might be useful
http://largiader.com/k75/khistory.html
5Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 4:48 pm
Greetings from north of Bris. The amount of Brick riders is growing, plenty of advice and help, both north and southside. Where in Bris are you??
6Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 6:50 pm
Welcome StandardK Smile
New K owner, greetings!  Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
7Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 7:35 pm
StandardK
StandardK
92KK 84WW Olaf wrote:If you look on the cam cover on the left side you will see two small allen bolts ['engineering screws'] near no 4 cylinder, on on the upper [intake] cam cover and the other on the lower cover near where your toes rest...hopefully. My engine is 48/83 and yours should be close.
Sound advice, much appreciated! I’ll have to do some detective work. 😀👍
8Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 7:36 pm
StandardK
StandardK
MartinW wrote:Greetings from north of Bris. The amount of Brick riders is growing, plenty of advice and help, both north and southside. Where in Bris are you??
Hi thanks mate, Northside - Over Stafford way. 😀
9Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 7:36 pm
StandardK
StandardK
Arlina wrote:Welcome StandardK Smile
Thanks! 😀👌
10Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 7:48 pm
Woo hoo
Another Brisbane rider
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
11Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 9:08 pm
welcome aboard
12Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 10:18 pm
StandardK
StandardK
Matthew-Brisbane wrote:Woo hoo
Damn straight!  cheers
13Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 10:19 pm
StandardK
StandardK
charlie99 wrote:welcome aboard
Thanks 😀👍
14Back to top Go down   New K owner, greetings!  Empty Are these ones you mean? ???? Thu Nov 28, 2019 10:58 pm
StandardK
StandardK
New K owner, greetings!  91b36610
The upper & lower bolts?
15Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Thu Nov 28, 2019 11:51 pm
Welkom SK.
16Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Fri Nov 29, 2019 1:33 am
StandardK
StandardK
TacKler wrote:Welkom SK.
Thanks😀
17Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 5:20 pm
StandardK wrote:New K owner, greetings!  91b36610
That's them.....you got one of the treasured early ones.....enjoy it.
18Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 5:51 pm
Std what is it's current state? Is it running? If not there are a few things you should check clean or replace before attempting to start. Everything in and outside side the fuel tank should be checked. Fuel lines can harden and disintegrate, fuel filter can block up, fuel pump damper (mount) can turn to Vegemite, fuel rail can have internal corrosion, lower portion of the fuel tank can suffer from corrosion. This once used to be a really expensive fix in OZ the submersible fuel line once was $100.00 a Mt can be obtained locally $17.00 Au expensive fuel pumps can be had for $37.00Au. Rear master cylinders can be had for $15.00 Au. These are just a small example so it's better to ask the local guys before committing to expensive OEM parts and tools. There are a group of us that share knowledge, resources, tools and rides and you are welcome to join and it's free to ask questions.
19Back to top Go down   New K owner, greetings!  Empty New K Owner Sat Nov 30, 2019 6:02 pm
Pegasus
Pegasus
Welcome to the asylum Smile
I'm out Ipswich way.
20Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 7:20 pm
92KK 84WW Olaf wrote: There are comments on the use of unleaded gas in these engines so keep an eye out on that one. I haven't noticed anything amiss so fat but have only put 4k miles on it since I got it with 29k miles.
They don't have hardened valve seats like the later models. At 4C in this Brick-related section of his website, Snowbum recommends checking and adjusting the valve clearances more often than is recommended for the later models. BobT sums up his view here.
21Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 10:47 pm
StandardK
StandardK
Excellent! 😀👍
Is there much of a difference between the very early ones? Due to cam profile or something?
22Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 10:54 pm
StandardK
StandardK
MartinW wrote:Std what is it's current state? Is it running?
Hi Martin,
She sure is - i’ve had it running a few times & ridden her round the block. It’ll need going through top to bottom, the tank appears clean at least but I’ll be doing the pump, damper, lines etc. The cooling system appears ok, brakes do work, but everything needs a good going over.
Thanks for the tip regarding the parts cost - looks like most bits are quite affordable apart from the damper? I’ll be scouring the forum & asking plenty of questions over the next year i imagine!
23Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 10:57 pm
StandardK
StandardK
Pegasus wrote:Welcome to the asylum Smile
Thanks Pegasus - we may well cross paths at some stage...I do the esk/fernvale/crows nest loop out your way fairly regularly.
24Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 10:59 pm
StandardK
StandardK
Ok thanks Laitch- i was planning on using some valve saver stuff per tank once she’s up & running, i’ll be checking the valves too.
25Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 11:08 pm
It would be a good idea to change all the fluids, brake, forks, coolant, drive train, engine. Check the valve clearance which rarely requires adjustment. Once serviced and back up and running they are virtually bullet proof if maintained. The worst thing you can do with a Brick is not ride it, they do not like sitting.
26Back to top Go down   New K owner, greetings!  Empty Welcome Sat Nov 30, 2019 11:24 pm
daveyson
daveyson
Welcome
I'll have to keep an eye out for your avatar to find more differences between the early model and your early early model.
 ~120,000 km
27Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 11:46 pm
StandardK
StandardK
MartinW wrote:It would be a good idea to change all the fluids, brake, forks, coolant, drive train, engine. Check the valve clearance which rarely requires adjustment. Once serviced and back up and running they are virtually bullet proof if maintained. The worst thing you can do with a Brick is not ride it, they do not like sitting.
Yup, agreed on all points. The forks/seals look ok but I’ll do the oil at least, probably best to put a seal kit in too i’m guessing.
28Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Sat Nov 30, 2019 11:49 pm
StandardK
StandardK
daveyson wrote:Welcome
I certainly have no idea, brick-ignorant at this current time! 😂
29Back to top Go down   New K owner, greetings!  Empty Re: New K owner, greetings! Tue Dec 17, 2019 6:11 pm
playlikewedream
playlikewedream
Welcome
New K owner, greetings!  177912
New K owner, greetings!  Ir-log10New K owner, greetings!  Ir-log10
;BMW; K1 1990 Laguna Blue and Yellow ;BMW;
;BMW; K1100RS 1997 Sedien Blue.;BMW;
Its not about the journey or the destination, it's about the friends you make on the way.
