1Back to top Go down   Choke control positions Empty Choke control positions Tue Mar 10, 2020 7:54 am
Cablebeacher
Hi all out there
A quick and probably slightly silly question. And yes I did search the forums...
My K100 RS CHOKE lever is really a FAST IDLE lever. Yes. Got it.
But the question is "does it have one "locking" position or two?"
Mine only has a first locking position and you can manually push it to rev higher.
I have a recollection that a previous K75 had TWO locking positions?
Or am I imaging it...
Regards
Mal
Broome
AUSTRALIA
Last edited by Cablebeacher on Tue Mar 10, 2020 7:56 am; edited 1 time in total (Reason for editing : Bad grammar and punctuation...)
2Back to top Go down   Choke control positions Empty Re: Choke control positions Tue Mar 10, 2020 8:48 am
My K100RT only has a single locking position about halfway through the travel.
3Back to top Go down   Choke control positions Empty Re: Choke control positions Tue Mar 10, 2020 9:12 am
You are not imagining. Some lock in either position, some only lock in the first setting.
4Back to top Go down   Choke control positions Empty Re: Choke control positions Tue Mar 10, 2020 9:53 am
Is it something that was added to later models?
My 1994 K75RT holds anywhere beyond the middle position, but my earlier bikes only hold the middle position.
5Back to top Go down   Choke control positions Empty Re: Choke control positions Tue Mar 10, 2020 11:34 am
Point-Seven-five wrote:Is it something that was added to later models?
My earlier Ks are like that, 92 K100LT would hold any position. BUT...97 K1100LT only holds one position.
However I rarely use it, just fire up and ride.....
6Back to top Go down   Choke control positions Empty Re: Choke control positions Tue Mar 10, 2020 1:56 pm
If it holds in any position other than half (or in some cases full as well) then it needs to be cleaned and freshly re-lubed.
ETA: Or it's possible that the cable is worn and needs to be replaced.
7Back to top Go down   Choke control positions Empty Re: Choke control positions Tue Mar 10, 2020 8:26 pm
1992 K75s definitely a detent click at half and full.
