1Back to top Go down   2 questions regarding cutting frame Empty 2 questions regarding cutting frame Sun Aug 02, 2020 7:45 am
DanielBN_K100
DanielBN_K100
Im in the middle of turning my RS into a cafe racer and need som advice regarding cutting the frame and also about brakelights.
Alright! First question: i dont want to put on a loop but keep the tubes sticking out. If i cut Well before the spring, do i still need to put anything in between the tubes to make the frame sturdy?
Second question: i would like to put some brakelights into the tubes to close them off.. does anyone have experience with this? I fear that lights needs to be custom fitted since its a weird size inside the tube. Cant find any here in Denmark Sad
Thanks alot in advance Smile
DanielBN_K100
DanielBN_K100
2 questions regarding cutting frame E5ed1310
DanielBN_K100
DanielBN_K100
Something like this
2 questions regarding cutting frame Abfe1510
We have a member who's got you covered if you have SBLFCR* in the near future.
Here is a LINK to his generous offer.
Good luck with your project.
Is there a tongue in cheek emoji?
*Sudden But Lingering Frame Chop Regrets
How we spend our days is, of course, how we spend our lives. - Annie Dillard, author - born 30 Apr 1945
That second pic looks like it's using a 3mm or 4mm flat bar to brace across the back. Yes; you need a brace, otherwise the frame is going to flex like crazy.
