1Back to top Go down   K75 Steering head seal? Empty K75 Steering head seal? Tue Feb 23, 2021 12:20 am
roach374
roach374
In taking apart the steering head on my '93 K75 standard to replace the bearings, there's some sort of seal between the upper and lower bearings, with two retaining screws that hold it in place (You can sort of see what I'm talking about at 16:47, here).
When I look at realOEM for my bike's serial number, it doesn't show up in the parts fiche at all. IT doesn't even show the retaining screws that stick through the steering column to keep the seal in place.
Does anyone know what I'm talking about? What's the BMW part number for this mysterious seal that I can't find in any parts diagram?
1993 K75 standard
2Back to top Go down   K75 Steering head seal? Empty Re: K75 Steering head seal? Tue Feb 23, 2021 12:37 am
It's the Fluid Bloc steering damper.
3Back to top Go down   K75 Steering head seal? Empty Re: K75 Steering head seal? Tue Feb 23, 2021 1:33 am
roach374 wrote:When I look at realOEM for my bike's serial number, it doesn't show up in the parts fiche at all. IT doesn't even show the retaining screws that stick through the steering column to keep the seal in place.
Use only the last seven digits of your moto's serial number. You also needed to look in this section.
K75 Steering head seal? Scree129
Regardless, here is the realOEM page you couldn't find. Scroll down for the part numbers.
4Back to top Go down   K75 Steering head seal? Empty Re: K75 Steering head seal? Tue Feb 23, 2021 4:44 am
Point-Seven-five wrote:It's the Fluid Bloc steering damper.
What he said.
From memory it was introduced around 1991 and is generally a pain in the rear end.  The grease inside them dries out and makes it a pain when trying to set up steering head bearings.
5Back to top Go down   K75 Steering head seal? Empty Re: K75 Steering head seal? Tue Feb 23, 2021 6:45 am
The special grease is still available as Dow Corning High Vacuum Silicone Grease.
6Back to top Go down   K75 Steering head seal? Empty Re: K75 Steering head seal? Tue Feb 23, 2021 3:45 pm
roach374
roach374
Laitch wrote:Regardless, here is the realOEM page you couldn't find. Scroll down for the part numbers.
As usual, Laitch, coming through in the clutch. Thank you!
MartinW wrote:The special grease is still available as Dow Corning High Vacuum Silicone Grease
Thanks MartinW, What's so "special" about this grease? Could I use red grease, SuperLube, or white lithium or something instead?
1993 K75 standard
7Back to top Go down   K75 Steering head seal? Empty Re: K75 Steering head seal? Tue Feb 23, 2021 4:05 pm
The grease is extremely thick, and the Fluid Bloc is designed to use that particular grease. A tube of that grease will last you and your ancestors for many generations to come. I've found other uses for it. It can be packed between the upper dust seal and the fork seal to stop the ingress of dirt and water. I've never had to change my seals in over 20 years, replace the grease every year or two. I also use it under the boot of my rear master cylinder to stop water and road crap ingress. A lot of master cylinders I've seen have corrosion around and under the boot.
