Number of posts : 7899
Rockman wrote: Dai wrote:Lift the tank and check the cables on the handlebar switches. You may find that there's an extra length of cable folded back and taped up - I've seen this twice now (on a naked and an RS) and can only assume that BMW built handlebar switches to cover the RT as well. That might save some grief. Naked bars should fit without having to worry about the control cables.
You are probably right. I'll check it out.
That is correct. The RS has the extra length on all the handlebar wiring and switches looped up under the tank. No difference between RT/LT and RS on those. I have Ks with both and you can unloop the extra length if you need it. Throttle cables are in multiple lengths depending on the exact model. Clutch cable is either long for RT/LT or short for RS. Front brake pipe from master cylinder differs. I think choke cable differs too but I never use it. I just fire up and go. Its only a throttle advance anyway so its the same thing to just give it a bit of gas.
1971 Yamaha 125 YAS-1
