1Back to top Go down   FS K100 Bits Pieces Empty FS K100 Bits Pieces Fri May 20, 2022 3:24 am
G'Day all, I need to have a shed clean out so all this stuff has to go. Parts are mainly for early K100s so here goes:-
  Radiator and various associated bits and pieces plus 2 Spal Fans
  Pannier Z frames 2 x RH , 1 X LH
  Rear Mudguard, rear cowl base, no.plate holder, rear top cowl.
  Brake rotors (F), 4mm, run out unknown plus a few other brake bits
  Coil Cover
  Air Box
  FICU x 2
  RH Lever perch - no master cylinder
  Exhaust Heat Shield
  Centre Stand
  Handle Bar RT
  Handle Bar, possibly RS ready for heated grip wiring
  RH Foot peg hanger with brake lever and switch, early model
  LH Foot peg hanger early model X 2
  Swing Arm with Gaiter to gear box
  Exhaust muffler
  Hagon Short Shock
  Tail Light
  Dashboard with ignition switch inlet on LH side
  Pannier Latches X 3 with key
  Mirror, round short stem L & R
  RT Fairing upper, complete with headlight and indicators plus associated brackets and fittings
  Rear Wheel
  Other little bits and pieces
  Instrument clusters X 2
I would prefer for this lot to go in one lot for about $400. Please PM me.
Tom
2Back to top Go down   FS K100 Bits Pieces Empty Re: FS K100 Bits Pieces Tue Jun 07, 2022 12:10 pm
warmshed
warmshed
There is a for sale section on the forum . Might be better than this electrical trouble shooting and repair section.
3Back to top Go down   FS K100 Bits Pieces Empty Re: FS K100 Bits Pieces Tue Jun 07, 2022 8:26 pm
Thanks I had not picked up on that. It's been moved and Tom you owe me a beer.
4Back to top Go down   FS K100 Bits Pieces Empty FS K100 Bits and Pieces Wed Jun 08, 2022 7:30 pm
Thank you gentlemen. I had also not picked up on that. Thanks for the removal and relocation. Too cold for beer at the moment but how about a honey bourbon? Cheers Tom
5Back to top Go down   FS K100 Bits Pieces Empty Re: FS K100 Bits Pieces Wed Jun 08, 2022 8:34 pm
I'll drink to that drunken
