1 Wanted blinker relay unit for a K75C Tue May 16, 2023 5:29 am
Rockman
They are probably all the same for the K75 & K100. Mine is either slow, or not at all..
Have you swapped the regular incandescent bulbs in the signals for LEDs? What wattage bulbs are you using if you are using incandescents?Rockman wrote:They are probably all the same for the K75 & K100. Mine is either slow, or not at all..
Dai wrote:Don't forget to give him some blinker fluid to go with it.
Very possible, except in my case it would be both sides. I noticed yesterday that if I push the switch a bit harder it works better sometimes. When I get a chance I'll take them apart and clean the contacts.charlie99 wrote:Possible corroded switch contacts in the rhs ?
Similar topics
