1Back to top Go down   K100RT 86 Fuel sender unit  Empty K100RT 86 Fuel sender unit Wed Aug 09, 2023 5:04 am
EngineerDK
EngineerDK
I need a functional fuel tank level transmitter.
New or used.
Please send a PM.
Wbr. Jan
Copenhagen
2Back to top Go down   K100RT 86 Fuel sender unit  Empty Re: K100RT 86 Fuel sender unit Wed Aug 09, 2023 4:05 pm
https://www.motorworks.co.uk/fuel-level-sensor-tak59565-1.html
You will be very, very lucky to find one on ebay - I know, because I've been looking for one for many months now.
-Dai
3Back to top Go down   K100RT 86 Fuel sender unit  Empty Re: K100RT 86 Fuel sender unit Wed Aug 09, 2023 4:23 pm
Suzi Q
Suzi Q
Assuming you mean the later, flange type fuel sender then yes, completely agree with Dai - they are rare and expensive.
I've accepted that, next time I need one, I'll instead set about repairing the one I've got. The rheostat is 'standard' 0-100 ohm in common with many other sender units, so a cannibalised repair should be possible. If, as happened to me, the connections seem to to go open circuit as they pass through the square flange, then that can be caused by fractures in the actual conductors within the plastic bushing. There is a way to fix this, but it's a bit involved and it really needs to be reliable, given its location.
4Back to top Go down   K100RT 86 Fuel sender unit  Empty Re: K100RT 86 Fuel sender unit Fri Aug 11, 2023 2:13 am
just a heads up ,
thinking of going into restoration of the fuel sender units
including
electrolysis removal of rust etc
replating of metal parts involved
rewinding the rheostat
resoldering the connections
providing new cables to the pump
have found some suitable cable for the rheostat
which will involve testing the process (length , resistance , terminations )
fingers crossed it goes all ok .....soon
5Back to top Go down   K100RT 86 Fuel sender unit  Empty Re: K100RT 86 Fuel sender unit Fri Aug 11, 2023 6:17 am
Wishing the very best in your endeavor.  You are doing the lord's work.
6Back to top Go down   K100RT 86 Fuel sender unit  Empty Re: K100RT 86 Fuel sender unit Fri Aug 11, 2023 4:26 pm
Well Charlie, it had to be you, me or Chris (SuziQ) having a go at it but I think you got there first! K100RT 86 Fuel sender unit  44271
