1Back to top Go down   Desperate.... K100RT 1985 - starting Empty Desperate.... K100RT 1985 - starting Wed Feb 07, 2024 1:53 am
Kendallsr
Kendallsr
It's been a journey and it's only been ten days since I bought the bike as a non runner and had been sitting for 15 years.....
New Oils all round.
New plugs
new petrol pump
Injectors removed and professionally cleaned and they all squirt well
Fuel moves in the tank and comes in & out via the respective fuel lines
Fuel filter new and facing the correct way.
Have 7 litres on fuel
Check earth under seat and the one by battery  - both cleaned
Spark plugs spark and connected in the correct order....
All lights works and brake light switches
Ignition on, all lights are on
Starter button pressed - fuel pump kicks in and the engine starts
with 2 to 5 second ds the engine stops
It doesn't like any throttle
removed the Throttle connection to the right of the injectors no change
Borrowed an ECU and tried this - no change.
Frustration and lots of swearing and still no further forward.
I'm not a mechanic just an bike enthusiast but in desperate need of some please...
Thanks, Stephen
2Back to top Go down   Desperate.... K100RT 1985 - starting Empty Probs Wed Feb 07, 2024 2:38 am
daveyson
daveyson
One thing to try, have a look at the coils. They might be swollen or have cracks, then test them anyway. In the electrical section you will find a troubleshooting guide which includes testing the coils.
I've had that problem, if I persisted, it would eventually get going when the engine was warmer. From memory, I think there was no continuity between the HT terminals on my bad coils.
There were quite a few changes in 1985, yours is the  earlier version, in which the coils weren't too good.
 ~120,000 km
Also check the spark plugs to ensure they have thimbles/nuts/screw terminals on and that they are tight (the bit that screws on/off the top - new plugs don't always come with them) and take a look inside the plug caps to see if there's any copper oxide (green crud) in there. This is what I'm talking about:
https://www.ebay.com.au/itm/115501639940?hash=item1ae46f2904:g:s5UAAOSwux5YWP4l
Yes, it's ebay Australia but I couldn't find any Australian sellers.
Next time you try to start it, keep your finger on the start button and see if it stays running while you are holding the button pressed.
The fuel pump gets its signal from two sources. The first is the start button but once the engine runs it comes from the Hall Sensors. If it stays running with the button pressed......check out your connection under the seat to the fuel injection control unit.
Now you mention the 7 liters of fuel. Having been down this road a few times caused by previous owners, if the fuel pump is not fully home in its mounting it runs out at about 13 litres......or a little over 7 litres left in the tank. My K1100 did this just recently. I just pulled the pump and reseated it correctly and problem solved. The early fuel pump mounts and dampers were not good, I have all mine swapped out. You should have a white plastic mount with one side slightly cut off so its straight. If not I would replace it with one.
So its possible the 7 litres of fuel is not actually enough to get the engine to run correctly.
Another high risk area on your K is the electrical plug into the tank. Check the terminals on the plug and if you need you can adjust them to make a better fit.
Dai wrote:Also check the spark plugs to ensure they have thimbles on and that they are tight (the bit that screws on/off the top - new plugs don't always come with them) and take a look inside the plug caps to see if there's any copper oxide (green crud) in there.
Been there too. If you are using NGK D7EA or D8EA they dont come with these on them.
Kendallsr wrote:It's been a journey and it's only been ten days since I bought the bike as a non runner , . . ..
What's the problem here? It's delivering as advertised. Laughing
The mixture could be too lean. The Z-tube connection from the crankcase to the airbox could be cracked, the vacuum caps could be missing from each of three throttle bodies and the fourth's hose could be cracked. In addition all the intake manifold connections could be compromised. These defects allow unmetered air into the fuel mix—a condition that can cause difficulty starting and poor performance in general.
15 years could have allowed mouse housing developments in the air filter.
Don't get the impression that you're into a unique circumstance somehow. Yours is a shopworn tale, but it often has a happy ending, if you develop patience.
One more caution. After the Brick's being idle for 15 years, the piston rings could be stuck and lowering compression. Remove the plugs and spray fogging oil or a small amount of motor oil into each cylinder then try starting.
Kendallsr
Kendallsr
daveyson wrote:One thing to try, have a look at the coils. They might be swollen or have cracks, then test them anyway. In the electrical section you will find a troubleshooting guide which includes testing the coils.
Thank you, as a new day begins here, my first task is to review the coils.  I'll let you know what I find.  Thanks
Kendallsr
Kendallsr
Dai wrote:Also check the spark plugs to ensure they have thimbles/nuts/screw terminals on and that they are tight (the bit that screws on/off the top - new plugs don't always come with them) and take a look inside the plug caps to see if there's any copper oxide (green crud) in there. This is what I'm talking about:
Thank you, will check today however from memory they all had the caps on top.
Kendallsr
Kendallsr
Have had the coils out.  They  have been unchanged and most likely untouched.
Both good.
Had the plugs out, they were a bit wet but cleaned them although were new 10 days ago.
On a positive note, the bike starts and idles well for 20 minutes.  The fan came on.
But still cannot throttle up.
One question, the fuel pump runs continually once started and idling??
firstle
firstle
flow meter flap stuck maybe ? the pump will run none stop
Kendallsr wrote:Have had the coils out.  They  have been unchanged and most likely untouched.
Both good.
How were they determined to be good?
firstle
firstle
have you a fully charged battery ? i have had a K that would start but not rev , battery was shot and took me a while to notice , simple things over looked  Crying or Very sad
Kendallsr
Kendallsr
Both good.
Had them out and tested with the multimeter... Readings on both coils the same.  Have a small clip of the bike running and testing of coils... Can't seem to load this here.  Thank for your response
Kendallsr
Kendallsr
firstle wrote:have you a fully charged battery ? i have had a K that would start but not rev , battery was shot and took me a while to notice , simple things over looked  Crying or Very sad
Have a new battery on order and hopefully here tomorrow... That would be a great fix!.  Thanks
Kendallsr wrote: Have a small clip of the bike running and testing of coils... Can't seem to load this here.
What's usually done here is the member posts a public video on YouTube the posts the video's link in the thread.
Kendallsr
Kendallsr
What's usually done here is the member posts a public video on YouTube the posts the video's link in the thread.Feeling dumb.... Okay.  Thank you
18Back to top Go down   Desperate.... K100RT 1985 - starting Empty Clip of bike starting and idle... Thu Feb 08, 2024 2:21 am
Kendallsr
Kendallsr
Clip with bike starting... Have managed to get it to run longer but cannot throttle....
https://www.youtube.com/shorts/0GWo329hEJk?feature=share
firstle
firstle
any fuel in the tank and have you changed the filter
Have you checked for debris restricting the air filter within the air intake box, and the snorkel that leads to it?
Kendallsr wrote:Borrowed an ECU and tried this - no change.
Which ECU did you borrow and try—the ignition control unit or the fuel injection control unit?
Kendallsr
Kendallsr
Hi, the fuel injection control unit... The silver square box that sits above the battery.  Thanks
Kendallsr
Kendallsr
firstle wrote:any fuel in the tank and have you changed the filter
Thanks, yes changed the petrol filter with the new pump
Kendallsr wrote:Had them out and tested with the multimeter... Readings on both coils the same.
I'm stuck here looking for clarity with quantification. What units on the multimeter were you measuring at the coils; from which terminals were you taking measurements and what were the readings?
firstle
firstle
Thanks, yes changed the petrol filter with the new pump , thats the fuel filter not the one on the base of the pump , is that correct .
sounds like an afm issue
crazy frog wrote a faults finding tutorial a while back specifically referring to afm measurements
in some cases the electrical connector into the afm can corrode inside the unit as it touches the pc board holding the electronics board ...and often the sprung connection from the vane to the armature can also be near open circuit
these issues can be repaired  with care and knowledge .
the reason for saying afm is because , i have seen many similar issues where the injection controller ..*(under seat computer )  has a minor heart attack at any movement of the vane wiper not connecting properly as the resistances the efi computer expects to see , just go wild when an open circuit appears , when it shouldnt
good luck
27Back to top Go down   Desperate.... K100RT 1985 - starting Empty Success.... Fri Feb 09, 2024 3:00 am
Kendallsr
Kendallsr
Success comes to those that persevere.  Thanks to all those that contributed, I certainly learnt a lot about the bike which will hold me in good stead...
Always the basic that catches us out.  The first job I did when getting the bike was the service: new plugs, fuel filter, oil filter, oils and air filter.  Then onto new fuel pump, jets, etc.   After testing a few things I eventually got round to locating and getting to the fuel pressure sensor and 'Hall sensor".  However, when feeling around the back of the large black box above the air filter, I noticed it had adrift at the rear with a large air pipe not connected to the manifold (not sure this is the correct term) anyhow, managed to get my hand in there and with a bit of vaseline managed to get it back on and tighten up the large clip.... And that was the problem.  Bike, kicked into life and took some ten minutes to disperse all the oil I had put into the spark plugs.
Onto to the brakes now, new battery and new tyres and hopefully registration.
Thank you again for all the support.
Stephen
ReneZ
ReneZ
Hi Stephen, great to see you have it now fixed. No doubt great 'job satisfaction' Now ride the beast and have fun :-)
Cheers, Rene
Rene
BMW K100 - 1985 (0030029) Scotland Desperate.... K100RT 1985 - starting Rain
Kendallsr wrote:However, when feeling around the back of the large black box above the air filter, I noticed it had adrift at the rear with a large air pipe not connected to the manifold (not sure this is the correct term) anyhow, managed to get my hand in there and with a bit of vaseline managed to get it back on and tighten up the large clip.... And that was the problem.  Bike, kicked into life and took some ten minutes to disperse all the oil I had put into the spark plugs.
The bit with the air filter in it is the air box. The bit that the 90-degree intake connects to is the plenum chamber. You won't be the first one to have trouble with that.
George_Pap
George_Pap
Have had the same behaviour , found that the rubber manifold between air box and throttle bodies was teared / cracked next to the clamp . Fixed it with some rubber tape and waiting for the part to arrive . Give it a check and as already mentioned the Z breather hose inspection would be advisable
