1Back to top Go down   K models calorstat seal Empty K models calorstat seal Tue Apr 09, 2024 11:56 am
49BMWK1
Hi,
I have a lot of "K" radiator calorstats, but most of them have their seal missing or worn.
I made a search, but didn' find any replacement seal.
the made is Behr-Thomson, but now it is Behr-Mahle i think
The part ref is 1.151.85  (it opens at 85° !), external diameter is 48mm, thickness 2.2mm, flat u shape
Does anybody got a clue to find this seal, BMW frequently uses parts from automotive, so it is possible the calorstat was on a mercedes or other car.
K models calorstat seal Bandea11
Triumph Bonneville 650cc 1970, Moto Guzzi Le Mans III 1978, 3x BMW K1 1989/90, K1200RS 1997, K1200LT 1999
2Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Tue Apr 09, 2024 12:59 pm
The gasket is a Tridon ttg26. This information was posted on the forum by Charlie99. Here is a link to a catalogue showing which vehicles' thermostats use that gasket. TTG26 is first found in the Daewoo section of the catalogue—p. 12—but is found in other vehicles after the Daewoo section.
3Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Tue Apr 09, 2024 1:58 pm
49BMWK1
Thank you very much
As i guessed, this calorstat was used on many cars, Ford, Suzuki,...
I found an european supplier ( Tridon is Australian ), so i can order these seals (3.2€ each !) EPS FACET 7.9674 or EPS 1.890.674
One more proof you can repare/find after market parts for our K Bikes...
4Back to top Go down   K models calorstat seal Empty Thermostat seals Tue Apr 09, 2024 6:15 pm
Packo
Packo
I have a set of these on order and am awaiting delivery (ordered 26 March)
Tills - Thermostat Seals Kit
Looks promising and I will post up on the forum if the thermostat seal is the right one unless someone already has that info
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
5Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Wed Apr 10, 2024 3:11 am
49BMWK1
Woah ! super deal  ! I usually order at Tills, but didn't imagine they sell this seal ! Fabulous Tills, always accurate and cheap...
6Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Sat Apr 13, 2024 6:59 am
49BMWK1
EPS FACET 7.9674 or EPS 1.890.674 doesn't fit the thermostat, to thick and a bit too large in external diameter...
Are you sure the Tridon fits  ?
7Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Sat Apr 13, 2024 12:02 pm
49BMWK1 wrote:EPS FACET 7.9674 or EPS 1.890.674 doesn't fit the thermostat,
What is the relationship of EPS 1.890.674 to Tridon TTG26? The link you posted leads to an Italian supplier, not  tills.de, Tridon, nor any auto manufacturer. If you received the Tills seal, was the EPS number on the seal?
8Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Sat Apr 13, 2024 12:31 pm
49BMWK1
The relationship is the vehicule setting for both TG26 and EPS 1.890.674. They are supposed to fit the same thermostat...
I haven't ordered Tills seal yet, i was trying to find the correct seal before i knex Tills sells it.
9Back to top Go down   K models calorstat seal Empty Re: K models calorstat seal Sat Apr 13, 2024 1:52 pm
49BMWK1 wrote:The relationship is the vehicule setting for both TG26 and EPS 1.890.674. They are supposed to fit the same thermostat...
It is the correct vehicle setting but the page indicates by text within a red banner that it does not fit the Daewoo model that you selected. Why? scratch  We'll probably never know. K models calorstat seal 177381 K models calorstat seal Screen26
