1 Temperature Guage now working. Fri Nov 18, 2011 11:19 am
BEEJAY
When I bought my 88 K100RS in August, the temp guage was not working and fairly soon after I noticed that the Oil warning light was not working.
The usual check of grounding the wire to both senders showed the temp guage to max and the oil pressure light on.
Sourced replacement senders from James Sherlock and fitted them a couple of weeks ago. Oil warning light went out as soon as the engine started and the Temp guage started moving as the engine warmed up.
Had a 150 mile run on Sunday and with ambient temp of 12c, the guage came up to the halfway mark. In stop start town traffic, the guage came up to one division below red and then the fan cut in.
Next one is to sort an intermittent electrical fault, which blows a 7.5 amp fuse, but only when on full left hand lock with the engine running. With the engine stopped the fuse does not blow. Checked some of the wiring and it needs the top part of the fairing off as some of the wiring is poor with taped twisted joints. Will solder all the joints and replace the tape with shrink sleeving, hopefully solving the problem.
MPG so far is 48.
Bryan
MPG so far is 48.
Bryan
