1 Cylinder Head removal Fri 13 Apr 2012, 04:03
Removing the exhaust for better access for another job has left me with two wrung off Studs. I will have to remove the cylinderhead in order to bring it to an engineering shop to have them drilled out.
I've been reading the manuals and I'm still on a big learning curve with the k engine but as far as I can see the main tasks are:
Am I missing anything obvious or does anyone have any helpful tips?
88KE
- Remove lower faings (RT/LT) and radiator cover
- Remove tank
- Drain coolant system
- Remover air box
- Remove fuel rail
- Remove engine cover
- Remove Timing/Cam chain and sprockets
- Remove cyclinder head bolts and take off head
88KE
88....May contain nuts!
K75RTP - 1994
