1Back to top Go down   "Choke" Lever Empty "Choke" Lever Thu May 14, 2009 6:47 am
phil_mars
Quick question hopefully with a quick answer. The "Choke' lever on my '84 only stays open in the first position but in the second position has to be held open.
Normal or not?
Regards
Phil
2Back to top Go down   "Choke" Lever Empty Re: "Choke" Lever Thu May 14, 2009 10:45 am
ReneZ
ReneZ
Phil, that is normal. Cheers, Rene.
3Back to top Go down   "Choke" Lever Empty Re: "Choke" Lever Fri May 15, 2009 4:20 am
Hi Phil,
Coment, that is normal. That is not how my as new K100RS works, the choke lever which moves really freely will stay at either setting.
Jeremy
4Back to top Go down   "Choke" Lever Empty Re: "Choke" Lever Fri May 15, 2009 9:04 am
phil_mars
Thanks Rene and Jeremy and I had feedback from Roy as well who indicates his is like Jeremy's so we can assume an improvement in the later models.
Might have to investigate further....
Phil
5Back to top Go down   "Choke" Lever Empty Re: "Choke" Lever Fri May 15, 2009 10:35 am
The 1985 K100 choke will only stay in the first position and on the 1986 K75 it stays on 2 positions.
