1 ABS - Speedo sensor interaction Mon Nov 19, 2012 5:25 am
Rickmeister
Gurus...Does anybody out there know that if the speedo sensor pickup wire gets graunched / cut and the rear ABS sensor is still intact and you're still traveling at speed, does the ABS alarm come up on the dash board? In other words, is there any interaction between the speedo sensor and the ABS sensor in the ABS computer/electronic wizardry? Does the ABS computer have an I/P from the speedo sensor?
I imagine that there is, inasmuch as if the speedo is indicating that the wheel is still rotating and the ABS sensor indicates that the wheel has stopped rotating, thus reducing the brake pressure allowing the wheel to rotate again, before applying full pressure again, in that loop. But if the speedo I/P indicates that the wheel has stopped rotating, but the ABS indicates that the wheel is still rotating, with no brake applied, it should generate a fault.
This is pure supposition on my behalf. Any info in this matter would be greatly appreciated.
Rickmeister.
Rickmeister.
