1 TB´s synchronization at idle Mon Jan 21, 2013 2:18 am
japuentes
As part of the maintenance a TB synchronization was in order, as the last time (3years ago), using a comercial one, is deemed too expensive for the frecuency and the results obtained with the home made had been very good, so I got the required parts:
4 6cc descartable syringes
The 4 springs I used the last time (small enough to fit in to the syrynges)
Appropiate diameter hose
Small cardboard to fix the syringes
Wife´s heat glue gun
Assembled as per the pictures
On this one the vacuum distribution prior to synchronization
And here once synchronized
I put a drop of oil on the syringes to reduce friction.
Synchronization procedure is the standart for idle
Hope this helps
Best regards
JAP
Hope this helps
Best regards
JAP
1988 K100RS SE/ABS
