1Back to top Go down   Fitting Bigger Tyres Empty Fitting Bigger Tyres Thu Feb 07, 2013 11:08 am
twincarb
twincarb
I am currently running 130/90 17 on My rear.... and a 100/90 18 on the front....
It's time to get a larger rear going up to the 140/80 17 my question is can I keep the front as stock as it's got more meat on it than a Rib Eye Steak so don't want to bin it yet....
forgot to mention I am using BT45's at the moment...
Yamaha Thundercat
Fitting Bigger Tyres 169042Fitting Bigger Tyres 169034
2Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Thu Feb 07, 2013 12:56 pm
i have tried both the 130 and the 140 options twincarb ....same brand of tyre to the front and both were great i think im doing better with the 140 this time around, but still only about 7000 ks up yet
looks to me that i got a long way to go before it gets down to thinking about a change
btw i have the 110 on the front
3Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Thu Feb 07, 2013 1:24 pm
japuentes
japuentes
Hi there, I´ve been running 110/80 at front during the last 12000Km, I think you can not fit nothing wider there, at least on mine. At rear I had run 140/80 and now 150/70, the last being the limit for both wide clearances and rim size.
Best regards
JAP
Fitting Bigger Tyres 2854237993 1988 K100RS SE/ABS
4Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Thu Feb 07, 2013 6:31 pm
Themason
Themason
110/80-18 front and 140/80-17 rear works fine on the stock wheels. A shop once made an error and put a 120/7ZR18 front tire on my bike instead of the 110/80ZR-18 I thought I was buying and it fit fine. The difference in steering feel made me look at the tire sidewall and that is when I noticed the size was wrong, but it didn't rub anything. The shop was apologetic and replaced the tire with the size I wanted. If you are ever in a bind and need a tire right now, it is something to keep in mind.
1986 R-80G/S w/1000 cc engine
5Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 2:56 am
nino
Hi, did anyone try wider tyres, 120 front, 160 rear? Is it possible on rear without modifications (spacers)?
6Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 4:54 pm
Themason
Themason
Nino, like I said above, a tire shop once put a 120/70ZR18 on the front and nothing rubbed. I made the shop replace it because I noticed the difference in steering feel, but it does fit.
You can put a 4.5X18 rear wheel and 160/60ZR18 tire on the back of an early K and it will fit except for the stock K100 muffler. If you use a muffler from a 16 valve bike or aftermarket exhaust the collector will clear the tire adequately where the stock collector will rub. You cannot put a 160 tire on the stock, narrow rear wheel.
7Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 5:14 pm
nino
Tnx Themason, what about rear tyre of big enduros like GS 1200 150/70 17 on my old narrow rim?
8Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 7:05 pm
nino wrote:Tnx Themason, what about rear tyre of big enduros like GS 1200 150/70 17 on my old narrow rim?
A five spoke wheel is 2.75x17 and therefore too small for a 150mm tyre. The proper width wheel would be 4" wide for that size. Maximum tyre width for your wheel is 140mm in an 80 series.
9Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Mon Feb 11, 2013 1:55 pm
Themason
Themason
Dual sport tires on a K bike? That sound you just heard was my rectum slamming shut.
10Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Mon Feb 11, 2013 2:34 pm
twincarb
twincarb
Dual compound tyres would be the ideal!
Yamaha Thundercat
11Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Tue Feb 12, 2013 11:44 am
Themason
Themason
[quote="twincarb"]Dual compound tyres would be the ideal![/quote]
Lots of those from Dunlop and Avon.
12Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Tue Feb 12, 2013 5:39 pm
twincarb
twincarb
i guess in the 140 tyre range? my local place says they can't get any in the 130's...
Yamaha Thundercat
