2 Re: New 1991 K100RS owner Sat Sep 07, 2013 8:48 pm
Welcome to the forum Vannatta Looks like you got yourself a bargain there.
3 Re: New 1991 K100RS owner Sat Sep 07, 2013 9:18 pm
Vannatta20
Problems I found so far.
Vibes kinda bad at certain RPMS.
pulls to the right a decent amount when i let go off the bars at speed.
Bad intake rubber boot. temp fixed with rtv until new ones arrive. MASSIVE VACUUM LEAK.
Fuel injector sucking in air. Replaced all orings on the injectors.
Vacuum line from fuel pressure reg leaking fuel. FPR ordered just need time to install. 50$ from amazon..
Handle bars too far for my reach. Risers installed. Big help there
Temp gauge not working. faulty sensor in water pump. Dont know where to get one yet...
throttle cramps the palm of my hand BAD very quick. Risers help its just a heavy throttle i guess.
Rear turn signal out. New bulb installed
Fuel tank over flow always leaking a bit of fuel. Should I cap it off??
rear brake just started squealing bad. new pads i guess. part#?
Runs much better but smells rich.. I hope the fuel pressure reg fixes that but i doubt it will.
Need to.
Change coolant, tranny diff, and rear drive.
Replace any rubber hoses when i have it apart to change the rubber intake boots.
So far even though i have all these small problems i love the bike:)
Need to.
4 Re: New 1991 K100RS owner Sat Sep 07, 2013 9:53 pm
Once the engine is running as it should the vives will just about dissapear. I have a K1100 and right on 4000 it tingles but keeping it well tuned does help. I am putting a 2.61 ratio drive in to get better fuel economy and get the revs lower so the vives aren't right on the speed I sit on.
The temp sensor, try EME but they only list the ECU sensor.
As regards the heavy throttle check to see if the grip is binding on the housing its a common problem and of course the cable could be getting old and the teflon liner is cactus.
I know what you mean about the low bars, I love the RS models but cant ride them because of hand problems and one of the guys here is having carpal tunnel surgery very soon because riding was near impossible for him.
Some of the guys here have used the bars from a K75c which make things a bit better.
Pulling to the right, check the wheel alignment we have seen a bent and twisted swingarm here a while ago and tire wear can do it also worth checking the frame for true, they are a very strong frame but all the same can bend.
Check out this site it gives a wealth of info for the new owner http://www.verrill.com/moto/newkbike.shtml
5 Re: New 1991 K100RS owner Sun Sep 08, 2013 12:02 am
Vannatta20
I just read the temp sensor might need to be removed and cleaned. Corrosion will stop it from getting a ground. I checked the throttle and the resistance is in the throttle bodies and maybe the cable.
The tires are old and I should replace. Hopefully that will help. Thanks for the great reply
6 Re: New 1991 K100RS owner Sun Sep 08, 2013 4:21 am
k-rider
congrats on your new bike, it looks very nice, good luck with all the Little reps.
7 Re: New 1991 K100RS owner Sun Sep 08, 2013 5:25 am
yep new tires ..makes a huge difference to just about all bikes we have on the forum
the old tyre compounds have been revised in recent years ...all with positive results from the major brands
8 Re: New 1991 K100RS owner Tue Sep 10, 2013 11:44 pm
Vannatta20
i replaced the FPR and went ahead and replaced the leaking intake rubbers. I just went to the part store and used radiator hose cut to size to replace those pieces since the ones I ordered are going to take a long to time to get here. It idles higher now and the vibes are hardly there. The FPR solved the running rich issue. Im happy!
9 Re: New 1991 K100RS owner Wed Sep 11, 2013 12:33 am
Another win for the K Team!
10 Re: New 1991 K100RS owner Fri Sep 13, 2013 10:25 am
Der Ziegelstein
Welcome Vannatta!
It looks like the New Mexico sun has dried out the rubber bits. Also check the condition of the vacuum plugs on the throttle bodies as well as the "Z" shaped hose that leads from the crankcase to the air box. Vacuum leaks do find their way to the handle bars.
When you say fuel tank overflow I assume you are referring to the drain lines. One of those allows water to drain from around the fill cap and the other is a vent. If you are leaking fuel from either of these I would say the fuel lines inside the tank need attention as well.
You may just be best replacing all of the fuel lines as well as vacuum lines. The ethanol in the fuel really contributes to the degradation of the rubber.
The issue with the throttle may be the result of the friction screw that is located on the bottom side of the brake lever perch. It is a "poor man's cruise control". It has a knurled head about 3/4" in diameter. Try to back that off and see if the throttle frees up some.
Brick Pilot Jim
1987 K100RS "Ziggy"
2004 R1150RT "Dunkle Ruβ"
11 Re: New 1991 K100RS owner Fri Sep 13, 2013 12:59 pm
Vannatta20
The z bend hose is bad but I don't know where I can get a replacement? It seemed to stop leaking fuel after the fpr replacement so that's good at least now. I checked the throttle with the cable unhooked and its smooth as butter. Seems its just the throttle body return spring are just strong.
12 Re: New 1991 K100RS owner Fri Sep 13, 2013 2:28 pm
klamityboy
You can get the crankcase breather hose at most dealers or beemerboneyard
http://www.beemerboneyard.com/11151460480.html
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
13 Re: New 1991 K100RS owner Fri Sep 13, 2013 3:30 pm
Der Ziegelstein
Beemerboneyard is a good resource for parts. Fortunately these bikes are still very popular and dealerships still stock parts for them. Check out realoem.com to find part numbers and then copy and paste into Google to comparison shop.
Brick Pilot Jim
1987 K100RS "Ziggy"
14 Re: New 1991 K100RS owner Fri Sep 13, 2013 5:08 pm
had the same issue with a clutch cable ....unloaded was as smooth as ...but with even just a little loading was tight and grabbyVannatta20 wrote:The z bend hose is bad but I don't know where I can get a replacement? It seemed to stop leaking fuel after the fpr replacement so that's good at least now. I checked the throttle with the cable unhooked and its smooth as butter. Seems its just the throttle body return spring are just strong.
lubricated it with lanotech (lanolin based lubricant ) and a cable lube adaptor till I could buy a new one
good luck
15 Re: New 1991 K100RS owner Fri Sep 13, 2013 6:27 pm
Hi Venatta,
Good to have you with us, post your questions over in the technical section, not all of the gurus read the new member introduction section so they may miss your question.
16 Re: New 1991 K100RS owner Fri Sep 13, 2013 6:55 pm
welcome to the beautiful world of the K100.Vannatta20 wrote:Its super clean but has some miles 60,000.
60,000mi,.... The bike is just ready for serious riding.
CF
1986 k75, 1985 K100rt, |
17 Re: New 1991 K100RS owner Fri Sep 13, 2013 8:34 pm
Sounds like the bike is coming together nicely Vanatta, welcome to the Forum.
88KE
88KE
88....May contain nuts!
K75RTP - 1994
18 Re: New 1991 K100RS owner Tue Sep 17, 2013 11:23 am
Vannatta20
Planning on going on a month long rode trip start at the end of the month. Can't wait!
Similar topics
