Mike101
Mike101
Morning all,
          Yesterday i set about changing my air filter as i have no idea when it was last done.
I went online..did my research and it looked straight forward.
So i thought..right side panel off..tank up and thats about it.  Wrong.
No you will all come back to me telling me that i did it wrong but this is what i did.
I got the right hand panel apart and off no problem and i left the engine bars in place..wrong.
The i discovered that i need the take the left hand side off to get the tank up...ok did that.
Would the tank move....no.  The retaining clips are missing but i could not get it to move at all.
So i put it all back together...easier said than done.  Now i know how to do it it will be ok next time.
But my god what a pain in the **** it is just to change an air filter.
So after 4 hours i was back where i started at with a new air fileter still in the box.
Am i going mad or is this normal.
Mike
No worries mate, first time I got nuts too Smile
No need to lift the tank.
The right panel and the intake must be removed.
Then take the 3 clips from the box, remember their position.
Then you can slide the filter out to the right side of the bike.
Place the new one same as you removed the old one, and take a beer.
You need it, because now the clips have to go back Smile
I use a large screwdriver to help me.
After 20 beer put the intake back and place the panel.
Then take it for a ride.
Not as testride, you just deserve the ride Surprised-o:
Good luck!
Mike101
Mike101
Wheeldigger wrote:No worries mate, first time I got nuts too Smile
Good luck!
Are you sure i don't need to lift the tank.  I got the airboxe clips off but the top would not lift up as it was hitting the tank.
Mike
No need to lift the top of the airbox, slide the filter out.
Check your new filter, then you know why it can/has to slide Wink
Youtube tutor, at 09:24 he's gonna slide the new filter in.
https://www.youtube.com/watch?v=od4r7SoIPRo
To get the left rear clip on you will find it very much easier if you have a long nose set of pliers and even better a self locking set. I got a very cheap set as I never will be likely to use them anywhere else.
The filters are not an easy job first time. I have owned a K for 8 years now and worked on them before that and it is never just a straight forward job.How hard can it be to change an air filter 610153 How hard can it be to change an air filter 178468 How hard can it be to change an air filter 78846 How hard can it be to change an air filter 610153 How hard can it be to change an air filter 78846 💣 How hard can it be to change an air filter 61740 :smoke:
Changing the air filter is fairly easy if you know what you're doing. Both the top and bottom of the air filter have grooves in them that match up to the walls of the top and bottom halves of the air box.  However, the top left side of the air filter does not have a "wall" so the trick is to lift the left (or back if you're looking at it from the right) side of the air filter and slide the air filter out to the right of the bike.
MikeP
MikeP
Regarding the tank, you're going to want it off at some stage, even though you don't need it off to do the air filter.
I've found a couple of bikes where the rubber grommets on the frame mounting lugs have pushed through and locked the tank in place.
Suitably sized piece of timber, wrap it an a rag and use it to lever each of the rear corners up a little at a time.
It will pop out eventually.
I always lubricate the tank pins with red rubber grease but vaseline will do.
1992 K1
MikeP wrote:I always lubricate the tank pins with red rubber grease but vaseline will do.
I lube the rubber grommets with Armor All.
brickrider
brickrider
Ah, this takes me back to the first days when I attempted to bring the service up to date on my new-to-me K100RS.  There is no end to the little tricks to learn when working on these bikes for the first time.  I think I made every error humanly possible.  Shocked
Good advice here, but I'd add that it's nice to have a telescoping magnet handy to fish out the three clips on the air box - after you drop them down into deep, dark recesses of the engine. Sad
Amen to that bricklayer. The front and rear right hand side clips are not too bad but that one on the left, with long nose pliers, wire, torch and no helper, is a well, family forum so can't say. I've been in there about 6 times this year replacing rubbers and filter and throttle cable, so hoping that's it.
My tip is take the whole airbox off, replace all the hoses and cables in one hit and leave it for another 10,000klm.
Cablebeacher
Hi all
Read ALL the info on changing the air filter. Last time I was going to replace it I just gave up in the end. Well here we go again!
I found that squashing the black foam spacer on top of the box and pushing it forwards helped. The twisting and lifting the air box top and filter OUT & TO THE RIGHT helped. Still a bit of a pain though.
And then I inspected the filter and blew it out with compressed air and found it was still really, really clean! Oh well...
Yes I did replace it anyway.
Regards
to all of you out there
Mal
Cablebeacher
When you have done a few filters you get to realise its not so bad. If you lose the clips they are same as the old Fiat airbox clips found in any breakers yard. Keep a few in your store!!!
The tip about the airbox off and repalcing ALL the pipes and hoses is a very good one. The fuel lines perish with age and the genuine fuel pipe is cheap. Put longer ones on the tank and you can slid and lift it for access to relay box and rad cap etc without disconnecting the fuel lines.
