1Back to top Go down   Fuel pump Empty Fuel pump Mon Dec 30, 2013 1:34 am
dowdytom
dowdytom
86 k100 rs fuel pump failure in castlemaine
Any hints?
2Back to top Go down   Fuel pump Empty Fuel pump Mon Dec 30, 2013 1:52 am
Not sure where I read this but if you can reverse the polarity (switch the wires over) and give it a brief start up it may spit out rubbish if it is blocked. The filter could also be cactus, try undoing the in line and have a go at starting see if fuel goes through the pump.
Other than that I'm out of ideas. Could also be under tank 4 pin connector came loose, undo and redo it up again.
Good luck. (do that first actually might save a lot of hassle).
3Back to top Go down   Fuel pump Empty Re: Fuel pump Mon Dec 30, 2013 1:55 am
Mate, here are a few ideas that should get you out of trouble.
Step 1. Find a Ford wrecker.
Step 2. Read below.
Quote from Rick
The pump I am using in mine is an after market for a EA EB ED Falcon Multi point Sedan. Those cars run an L Jetronic system as do many other cars of the era
If you get a pump for an EA Falcon sedan with multipiont injection and use a big zip tie and pull it real tight it works like a charm and I got one on fleabay for $45. You need to change the connectors to the push on spade terminals.
The fuel pressure is 32 -33psi
Quote from Rendrag
Bit late to the thread, but just watned to add (since this thread comes up on ebay every time I search Fuel pump Icon_wink), that in AUstralia, these fuel pumps (readily available at most parts stores) are almost a drop-in replacement for the K100 fuel pump (Note: the 52mm one, not the smaller..)
AC-Delco EP118AU
Goss GE053
Fuel Miser FPE-287.
I dropped the Fuel Miser variant into the bike this evening - $125 from repco. It's 51mm instead of the 52, so i cut a length of fuel hose into 4, and used two of them wrapped around the fuel pump where the 'lumps' are on the OEM one, and it all fitted up beautifully Fuel pump Icon_smile
4Back to top Go down   Fuel pump Empty Re: Fuel pump Mon Dec 30, 2013 2:12 am
Remove the fuel cap to get at the innards then remove the fuel line that goes from the top of the pump to the filter at the filter and see if it pumps then  WARNING keep the fuel line facing into the tank if you get flow put your finger across the outlet and try it and if you can hold back the pressure easily then the pump is cactus (it should pump 65-70psi).
Try what RT said about the 4 pin connector they are noted for going O/C.
5Back to top Go down   Fuel pump Empty Re: Fuel pump Sun Jan 05, 2014 12:12 am
dowdytom
dowdytom
Thanks for your quick and very helpful responses RT, Rossco and Rick
Finally trailered the bad girl home, minus left mirror/indicator housing and reg. sticker some K bike thieves in Castlemaine I think.
now for the investigation....
1986 BMW K100RS
to fang or not to fang...there is no question
6Back to top Go down   Fuel pump Empty Re: Fuel pump Sun Jan 05, 2014 6:39 am
nino
My advice is to check: 1. fuse 2. pump relay.
My problem was pump relay once, but i disasembled tank first and finally found problem in relay (after hour and half on parking lot). Relay is usually orange one in the corner of relay box (front left)
7Back to top Go down   Fuel pump Empty Re: Fuel pump Sun Jan 05, 2014 9:26 am
dowdytom
dowdytom
Good advice thank you Nino
1986 BMW K100RS
8Back to top Go down   Fuel pump Empty fuel pump Thu Jan 09, 2014 5:07 am
dowdytom
dowdytom
Finally got petrol sniffing and pulled the tank off and the pump out and after a good clean out, it wasn't too bad no grommet rot, put twelve volts through the pump and whrrrrrrrrr, woohoo put it back together and carved the macedon ranges with a huge grin.
thanks again you blokes for the VERY helpful advice
1986 BMW K100RS
9Back to top Go down   Fuel pump Empty fuel pump Mon Apr 14, 2014 9:22 pm
dowdytom
dowdytom
Fuel pump finally karked it after some intermittent non starts
ordered a bosch from the boneyard $318 landed
installation tomorrow
1986 BMW K100RS
10Back to top Go down   Fuel pump Empty Re: Fuel pump Mon Apr 14, 2014 9:40 pm
So you will have it going in time to come to the Nindigully get together and meet all the gang https://www.k100-forum.com/t7633-nindigully-ride-in-may
11Back to top Go down   Fuel pump Empty Re: Fuel pump Mon Apr 14, 2014 10:29 pm
dowdytom
dowdytom
I'm not an interstate trucker
but I'll be in Nambucca
In the wonderful month of May
Alas I can't bring my bike
'cause I'll be working on a house
Much to my dismay
you blokes have fun and I'll catch you on the next one
James
1986 BMW K100RS
