1Back to top Go down   Cylinder head question Empty Cylinder head question Wed Jan 15, 2014 11:37 am
ssj_Gill
ssj_Gill
Good afternoon chaps,
i'm tearing into my K100LT engine with a furry the likes of which has never been seen before and like a class A dope i sheared one of the big bolts that hold the cylinder head to the main engine block. managed to get it out but now it needs replacing (as do many many other parts).
does anyone know the part number? or a place where i can find the part number?
thanks muchly
2Back to top Go down   Cylinder head question Empty Re: Cylinder head question Wed Jan 15, 2014 11:46 am
Don't kill yourself over it shearing, happens everyone and is much more common than you think. If that was my engine I would be replacing them all anyway, whether or not its recommended, due to the age of engine etc.
I don't have the part numbers though but I suspect you will need engine number and someone here will be able to give you the part numbers. Motoworks or Motobins can probably do it on the phone.
Have a look here, its on the Portal section of the forum.
http://www.realoem.com/bmw/select.do?kind=M&series=K589&arch=1
3Back to top Go down   Cylinder head question Empty Re: Cylinder head question Wed Jan 15, 2014 11:55 am
mike d
Hi,
Part number 11 121 454 069 from http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51747&rnd=04302013
Can't see them on either the Motorworks or Motobinns sites.
Mike
4Back to top Go down   Cylinder head question Empty Re: Cylinder head question Wed Jan 15, 2014 11:58 am
Mike
That was fast. I got as far as finding the parts fiches. Would you go with replacing them all as a matter of interest?
Olaf.
5Back to top Go down   Cylinder head question Empty :D Wed Jan 15, 2014 12:31 pm
ssj_Gill
ssj_Gill
cheers fella, top notch responses as always. i think my biggest bloody outlay is going to be replacing all the bolts on this rebuild Razz
6Back to top Go down   Cylinder head question Empty Re: Cylinder head question Wed Jan 15, 2014 12:42 pm
k75RT Keith
k75RT Keith
For your rebuild, it's best to remember that the cylinders are nikasil and that honing is NOT recommended.  Scotchbrte pad works best
7Back to top Go down   Cylinder head question Empty Re: Cylinder head question Thu Jan 16, 2014 6:12 am
mike d
Personally,  would.
Mike
8Back to top Go down   Cylinder head question Empty Re: Cylinder head question Thu Jan 16, 2014 8:16 am
Very light with a medium grit and no oil or kero just run them under the hot water while you do it.
If they havent done many miles then not necessary but for the average K yes the bore can be so good and smooth that the rings will never bed.  BMW usually only deal with them in the warranty period
