1Back to top Go down   Introduction Empty Introduction Thu Mar 13, 2014 12:42 am
DaleRT
DaleRT
Hello, I'm Dale [DaleRT]
   I have been a member [maybe i should say a 'new member' and add to the 'Aussie invasion'] for several months
since getting hold of a 84' RT, few years ago. As you can imagine, having sat unused for some years then being used, issues arose.
   Just about all the documented issues have been visited, either i've replaced / renewed / reconditioned / rejuvenated / renovated / restored or revamped bits & pieces BUT with the help of the Forum never retreated.
   I'm just over 1600mm [bit under 5 1/2', in old money]. Commute each day and comfortable with the 'K'.
   So, possibly a longwinded way of saying THANKS for the many who have given their time, effort & posts to keep me ride'n'.
   Maybe a bit 'Cocky' but with what i've experienced,  I'll tackle the impossible with nothing - but the Forum.
   Again, thanks to all who participate in this Forum.          Dale
2Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 12:45 am
Hi Dale welcome to the Knuthaus. Glad we could help.
3Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 4:59 am
Welcome Dale, I'm guessing your probably further up the hill.
Introduction K-dogs10
4Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 5:19 am
welcome Dale , you know now that you have introduced yourself, pics are the next step .
great to hear that you have benefited from the experiences of this forum .
have to agree with Rick , a bit Knutty at times but enjoyable.
fill us in more on your works you have completed and what you intend to do.
Cheers Ed.
Introduction 10_x_110
5Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 5:21 am
Welcome to the magnificent magical mash of characters and their mighty machines.
6Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 5:37 am
good onya dale
many others would walk away from such an old beast ...but now you have persisted and achieved some goals ,,,we can be assured you have taste and impressive staying power .... grin
I have to say I appreciate you bobbing up and saying hi and the comments that you have expressed
there are some really good contributors here ...I applaud them all for making this place as good at it is.
enjoy ...and welcome to the forum
7Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 9:59 am
Dale,
Welcome too.
Why not change your name to DaleK? Then we would know who you are and what you look like!!!
8Back to top Go down   Introduction Empty Re: Introduction Thu Mar 13, 2014 1:19 pm
klamityboy
klamityboy
Welcome, I guess??? Since you have been here for a while, welcome doesn't seem quite right. Welcome back!!! No that doesn't seem right either. Oh screw it!!! Good to have you here. Very Happy
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
9Back to top Go down   Introduction Empty What's been done? THIS... Thu Mar 20, 2014 2:00 am
DaleRT
DaleRT
Hi to all,
   Yes, Al-58,, a bit further up than yourself and with a decent easterly, I’ll be out west
   groverK asked what was done, so, possibly for the benefit of newer owners …
New Battery then changed fluids and filters.
First hiccup, rear master cylinder ceased – new one needed & installed.
   Rear master cylinder reservoir replaced [Half of it came away when unscrewing the lid].
   Electrics / Lights all checked out OK, off for rego – registered.
      And away I went … So I thought.
Now the maintenance begins …
   Slack / play in the throttle response – fixed [alignment off]
   Fuel pump dies – new one
   Was’nt running that well,  not that responsive – throttle body rubbers perished – new bits
Introduction 12-e3312
Introduction 12-89510
While they were of,  replaced fuel lines, cleaned up injectors.  Engine vent hose perished – replaced
   Instrument cluster bracket broke
Introduction 12-ca410
   – fixed [it works]
Introduction 12-24911
   Speedo intermittent – working on it
      Gear indicator – intermittent [problem was the switch] fixed.   Alternator rubbers shot – replaced
Introduction 12-32f10
Introduction 12-8cd10
The new & the worn
Introduction 12-49610
   Starter playing up – cleaned it up, behaving it’s self now
Problem selecting gears, went for the grub screw, off with the gearbox.
  What you see, is the grub screw out and the seat slightly elongating.
Introduction 12-f0011
While in there …
   Fixed the gear indicator switch
   Rear engine seal
   New clutch
   Clutch lever boot leaking – replaced
[ When putting the ‘lid’ on the gearbox, I held the sprung arm, leaver back with fishing line, keeping the tension on the lever till I had several bolts in. Then slowly released the tension. The sealer was’nt disturbed. There is no leaking of oil and it has and does change gear. [not understanding much, don’t like to disturb what I don’t have to]]
Noisy fuel non-return valve – tried to fix [pulled it apart and tried to reseat the ball] unsuccessful, so dismantled and put one in fuel line.
Introduction 12-59f10
   Rear shock – shot, replaced – RAMS
   Replaced handle bar end weight ‘o’ rings
   New tyres
All the above were tackled because of being discussed on this forum – for that I’m greatfull.
To do’s …
Fuel level sender unit [thermistor] not working, thinking of taking it on.
Speedo – not fixed yet but I’m close.
The Speedo has an error of reading under the actual speed, be tinkering with that latter.
Want to do something about the seat, I’m sitting on a board after about 15min.
This is where I’m at, for now.      Dale
10Back to top Go down   Introduction Empty Re: Introduction Thu Mar 20, 2014 2:46 am
Yep looks like you have done the usual rounds there.  You'll be riding in no time.
11Back to top Go down   Introduction Empty Re: Introduction Thu Mar 20, 2014 3:25 am
Jeebus, I've seen lots of worn ones but nothing like that.
12Back to top Go down   Introduction Empty Re: Introduction Thu Mar 20, 2014 4:41 am
Dale,
That's quite some impressive list of jobs done. For someone that is armed with nothing more than determination and the forum and for someone that states "not understanding much, don’t like to disturb what I don’t have to" you have done good. Enough there to have even a seasoned mechanic cursing.
Hope the final few jobs also come good and you finally get to enjoy the bike. Of course the oil & toil is part of the fun of being in the K club and helps get to know the bikes inside out and gives immense satisfaction when they are running sweet and looking good again.
I wonder - had you known it was going to be so much work when you got the bike a few years back - would you have opted for a tinny by the billabong instead?
Introduction Uk-log10 Introduction Sco-lo15
                              Paul  Introduction 905546712
13Back to top Go down   Introduction Empty Re: Introduction Thu Mar 20, 2014 5:30 am
dale , you've really gotten in there mate . such determination , must be that K bug getting hold of you.
the rubbers seem to be the most prevalent at this stage, to be expected for a 30 year old bike, especially if it has sat awhile.
keep at it , you will gain so much from doing the work yourself. and these old girls are easy to work on , so I'm told .
14Back to top Go down   Introduction Empty Re: Introduction Sat Mar 22, 2014 8:34 pm
GTJos
GTJos
charlie99 wrote:good onya dale
 Very Happy Hi there, Dale ! A big +1 on the above comment from my side !
Enjoy and stay on the job, the bike sure is worth all your effort and will start paying you back soon...
Jos.
Introduction Deutch10Ich bin enge Kirchröatsjer jong; adieë wa ?! Introduction Deutch10
                                1992  K1100LT 6458188
                                1987 K100LT (RS-fairing) 0170844 + sidecar EML GT2001
                                1986 K100RS 0085647 + sidecar Velorex 562
                                1985  K100RT  0027026
