1Back to top Go down   On the road at last Empty On the road at last Fri Apr 25, 2014 10:48 am
carlmclelland
carlmclelland
Well after two months of fitting it in between work & other things I finally took her for the Mot this morning and she went straight through (phew).  I have never fitted a sidecar before but I must say that any question I had or any problem that arose was answered from this forum. Absolutely brilliant to get that sort of input when you need advice.
I would like to thank Sidecar Paul & Albyalbatross1 for sending me the drawings for their subframe designs, thanks a lot lads they were really appreciated. I decided to go for half & half as I had the materials for Alby's lower subframe design but I also liked Paul's idea of separate upper bar mounts. I wanted to try and avoid the continuing bars coming up the side of the bike  so with this in mind I constructed the lower subframe that fits the the engine & centre stand holes & used mounting clamps to the frame for the upper angled bars. The rear one was easy & the front one took a while due to me having to remove the radiator, hoses & some fairing etc. I had to make two cuts with my trusty Dremel in the belly pan cover so it fitted round the subframe & one cut on the side fairing for the front upper bar. It was worth it for me has I wanted to keep the bike as much like before has I could & I didn't want to loose any fairing parts. I'm just glad that the toeing in & the lean out were ok has this was my biggest worry. The front forks are too soft for my liking so I'm going to replace the fork oil with a 10w and take it from there. Also the rear shock is too soft so I will be on the lookout for a more rigid one. I replaced the standard BMW damper with an adjustable one as the original was shot but I'm considering a damper from the forks to the sidecar. I have rode solo bikes for 35 years but never before a combo and I have to say it was different, lol. Any views on the damper from the bike to the chair would be greatly appreciated.
Forgot to say the colour matching is not on my list this year so I can live with the sky blue & silvery white. Besides when I put my shades on it tones it down, lol.
On the road at last X_00511
On the road at last X_00611
On the road at last X_00810
On the road at last X_01510
2Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 10:57 am
Sure is looking good Carl
One thing I would suggest  would be to move the headlight and indicators to the front of the chair. The headlight will shine on the pale blue of the chair and be very bright in your side vision and the indicator would not be seen by traffic coming from your right as well as it could.
That is a real credit to you.
3Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 11:03 am
carlmclelland
carlmclelland
Good point Rick, I left the lights where they are now from when I bought the chair but what youre saying makes sense so thanks for the input mate.
4Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 11:14 am
That's some fine work you've done there. That 'rig' looks gorgeous.
Congratulations on getting it easily through the bureaucratic quagmire as well.
How we spend our days is, of course, how we spend our lives. - Annie Dillard, author - born 30 Apr 1945
5Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 11:22 am
great job carl ....looks a dream build
6Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 11:41 am
carlmclelland
carlmclelland
Cheers lads, I've just sent the V5 log book of to change it to a combo so I hope the DVLA don't pull mine out of the hat to go for a VOSA inspection and another lump of cash to pay for the privilege.
7Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 7:27 pm
10-ring
10-ring
WOW that looks great 🆒
8Back to top Go down   On the road at last Empty Re: On the road at last Fri Apr 25, 2014 7:58 pm
rear " WOOFERS" installed as well , nice touch.
looks a good solid unit there , well done , and thanks to the guys and their invaluable info here regarding outfits.
On the road at last 10_x_110
9Back to top Go down   On the road at last Empty Re: On the road at last Sat Apr 26, 2014 8:20 am
carlmclelland
carlmclelland
Thanks lads & has for the invaluable info it really is priceless to have so much help & knowledge on hand.
