1Back to top Go down   K100 snowflake wheel wanted Empty K100 snowflake wheel wanted Sun Aug 03, 2014 5:41 am
audibob
audibob
Hi guys, anyone have a k100 snowflake front wheel for sale.
I have been suffering brake pulsing and i suspect the wheel has been kerbed at some point. there a few on flea bay but thought i would try here first .
I am in nottinghamshire uk
Thanks Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 5:52 am
The term "snowflake" is used on the wheels on the boxers that was on the
market before the K, the early K wheels is called Y-spoke.
K100 snowflake wheel wanted Snowfl11
If you feel the pulsing trough the brake lever it's the brake discs that need
to be checked if they are true.
3Back to top Go down   K100 snowflake wheel wanted Empty K100 snowflake wheel wanted Sun Aug 03, 2014 8:56 am
audibob
audibob
Thanks Inge got my wheels mixed up a bit,  I need a y pattern then.  my front brakes have pulsed even with brand new discs, so must be  slight run on the wheel  itself. bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
4Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 9:58 am
Have you checked the mounting surface at disc hubs and at the wheel?
To get pulsing at the brake lever the disc(s) must move sideways relative
to the calipper.........a wheel that have bit of runout would not cause that.
It could maybe be felt in the handlebar when braking, but not at the brake lever.
I think it would be a idea to measure the discs for runout first.
Just trying to help, so you don't buy parts you really don't need.
5Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 10:15 am
What he said.  Pulsing brakes are usually caused by "warped" rotors.  Bent wheels usually cause wobble at speed.
6Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 2:11 pm
audibob
audibob
Thanks guys,
The disc hubs are clean , this problem was present with the old discs too. which is why i though it may be the wheel itself. The brakes are very grabby with the HH pads, especially at low speeds. High speed braking is smoother. I intend to replace the master cylinder and hoses during the winter . I have overhauled the calipers.
 This is the first time i have experienced grabby brakes on a bike.
 Would trying a new set of pads be worthwhile? The discs are EBC floaters with only 3k on them but I will check them .
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
7Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 4:05 pm
ABS euqipped bike? Some have reported pulsing brakes when bike has been close to stopping......
and it have been concluded that the reason was incorrect sensor/toothwheel opening.
8Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 8:30 pm
Duck has a front wheel but apparently it only fits on the back Rolling Eyes  scratch
9Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Sun Aug 03, 2014 8:38 pm
K100 snowflake wheel wanted 112350  Universal model.
10Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Mon Aug 04, 2014 12:54 pm
audibob
audibob
Thanks Inge, my bike has ABS, and the effect is only at very low speed when coming to a dead stop. There is no hint of it if the brakes are applied at speed. My ABS system shows no fault , could an incorrect air gap cause this without throwing a fault in the system? It does seem as though the lever is being pushed back , but then a badly warped disc would do this also.
I may check my air gap .
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
11Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Mon Aug 04, 2014 1:09 pm
audibob wrote: My ABS system shows no fault , could an incorrect air gap cause this without throwing a fault in the system?
If I remember correct, others who had this problem didn't report any fault code.
I would guess it's in a dark zone close to the widest gap...and is affecting the ABS,
but not bad enough to throw a fault code.
12Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Mon Aug 04, 2014 4:24 pm
audibob
audibob
Thanks Inge,
I will let you know the gap in a couple of days.
Thanks Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
13Back to top Go down   K100 snowflake wheel wanted Empty Re: K100 snowflake wheel wanted Tue Aug 05, 2014 5:16 am
the.postman
I have a large selection of shims for the ABS sensor if you need them give me a shout
1984 srx 600
1986 cbr1000f/h
