Number of posts : 7897
BooG wrote:Looks like I am only firing on one or two cylinders at mo. That would explain the smoke and occasional backfire. Would that old gas block up the injectors? Is that the most likely culprit?
Any consistency in which two cylinders are not firing? Just after you try starting up feel the headers and see which ones are cold. If 1 and 4 or 2 and 3 as pairs are cold then you have a coil issue, but maybe a connection and not the coil itself.
1971 Yamaha 125 YAS-1
