1 Engine stutter Sun Mar 15, 2015 12:10 pm
Big G
Hi guys
Having recently acquired a '90 K100RS, I have experienced an issue to which one of the members may have a simple solution.
The engine sometimes "stutters", almost as if fuel starvation or bad plugs. There is no fuel filter in the line to the injectors, and I have now realized that I need a 19 mm socket for the spark plugs (at least after this bike, I will have the full set - 16, 21 and now 19!), so I have not yet checked them.
I doubt however if the fuel starvation or bad spark is the issue here, as it does not occur only under acceleration. Sometimes, while cruising, or even when braking against the engine, I experience it. Under acceleration, I have kept the throttle open when this occurs, and after a second or two, the engine fires on all cylinders again (and then pulls like a tractor).
Could this be heat-attributed? I have noticed that the ignition leads are bunched up under the aesthetic spark-plug cover, and this condition seems to occur only once the bike has run for a while. (It is fairly warm down here now, around 30 deg C day temperature.)
