Number of posts : 4175
Here is one I made up. I printed it on both sides of a single sheet and laminated it. I keep it in the top drawer of my tool chest with my torque wrenches. Have only included the specs for the external stuff that gets worked on during general maintenance..
Torque Specifications
General Settings: Tire Pressure One Up:
5mm 30-40 inlb Front 32 psi
6mm 50-65 inlb Rear 36 psi
8mm 10-13 ftlb
10mm 20-25 ftlb Two Up:
Front 36 psi
Oil drain plug 15 ftlb Rear 42 psi
Oil filter cover 7 ftlb
Oil pan bolts 7 ftlb
Cyl Head cover 6 ftlb
Spark plug 15 ftlb
Engine mounts 30 ftlb
Timing chain cover 5 ftlb
Crank cover 6 ftlb
Water pump 5 ftlb
Trans to engine 11 ftlb
Center stand 28 ftlb
Shifter 11 ftlb
Trans mounts 30 ftlb
Exhaust flange
K75 15 ftlb
K100 11 ftlb
Muffler clamp 15 ftlb
Muffler mount 6 ftlb
Alternator bolts 16 ftlb
Starter bolts 6 ftlb
Foot peg mounts 11 ftlb
Rear Wheel bolts 77 ftlb
Shock mounts 36 ftlb
Front axle allen bolt 24 ftlb
Front axle clamp 11 ftlb
Brake caliper mount 23 ftlb
Front brake disc 20 ftlb
Rear disc 14 ftlb
Brake hose banjos 5 ftlb
Rear pedal pivot 17 ftlb
Master cylinder 4 ftlb
Handlebars mounts 15 ftlb
Fork clamp bolts:
Upper 15 ftlb
Lower 30 ftlb
Fork brace 15 ftlb
Fork slider 13 ftlb
Fork drain 6 ftlb
Final drive mount 28 ftlb
Filler plug 13 ftlb
Drain plug 17 ftlb
Swing arm:
Fixed 6 ftlb
Pivot pin 5 ftlb
Lock nut 30 ftlb
