1Back to top Go down   Tank insulation Empty Tank insulation Mon Aug 03, 2015 6:36 am
DaleRT
DaleRT
Hi, Taken the tank of the '86 RS to find a large part of the insulation not stuck to the tank. The glued surface that should be stuck to the tank has dust & dirt embedded in it. Removed all the insulation, so what could i use to clean/glue it back ?
   Cheers   Dale
2Back to top Go down   Tank insulation Empty Re: Tank insulation Mon Aug 03, 2015 8:09 am
I replaced all the insulation on the K1100 when I repainted. I think this is the stuff I used but not 100% sure, make sure it is fuel proof before getting it http://www.ebay.com.au/itm/OZ-Car-Sound-Deadener-Noise-Control-Heat-Insulation-Aluminum-Foil-Shield-1Mx0-6M-/121703689567?hash=item1c561aed5f
3Back to top Go down   Tank insulation Empty Re: Tank insulation Thu Aug 06, 2015 6:57 am
DaleRT
DaleRT
Thanks, was'nt sure what could be done or to do. Dale
4Back to top Go down   Tank insulation Empty Re: Tank insulation Thu Aug 06, 2015 7:41 am
One thing to be sure of is to cover the bottom of the tank well, the factory uses a precut piece that leaves large gaps for the heat to get at the tank.
5Back to top Go down   Tank insulation Empty Re: Tank insulation Fri Aug 07, 2015 11:42 am
And it doesn't necessarily have to be stuck to the bottom of the tank.
Tank insulation K11rs.blanket
6Back to top Go down   Tank insulation Empty Re: Tank insulation Tue Nov 03, 2015 4:27 am
floyd
floyd
Ive got the bottom of mine covered with Dynamat - which is expensive - and im unsure weather its actually doing anything??!
My tank becomes almost to hot to touch within about 15-20mins of riding.
I really must fit a fuel cooler. I have a billet alloy oil cooler for another project that Ill chuck on and see how it goes
