1Back to top Go down   wet spark plugs Empty wet spark plugs Tue Apr 20, 2010 3:24 pm
bigshrek
pleeese help i have a 1986 rt with 175000 miles on the clock the bike was running fine then it started running rough as if it has a missfire it wont idle at all the plugs are fine and are sparking ok. i have changed the throttle sensor the coolant sensor reads 4 ohms when tested i have also changed the air flow meter every time it runs up and then stalls it wont start again i take the plugs out and they are soaking the only thing i can see is the throttle bodies bottom seals look perished could it be that iam at my wits ends with it.
2Back to top Go down   wet spark plugs Empty Re: wet spark plugs Tue Apr 20, 2010 8:33 pm
reg_K100RS
Hi Bigshrek
175000 miles ??
Wow, I hope that means I have another 100000 left in mine
When you say coolant sensor do you mean the one tucked down just behind the rad ?
bottom left when sat on the bike?
I had the rad off mine last week when working on it and recall measuring across the terminals and
getting something more like 4-5 Kohms (engine cold, ambient temp of about 16 degrees)
Not sure if this is significant or helpful though.
Reg
3Back to top Go down   wet spark plugs Empty Re: wet spark plugs Tue Apr 20, 2010 8:48 pm
reg_K100RS
Just did a search and found this thread
http://k100rt.aforumfree.com/electrical-f8/oh-dear-and-now-temp-issues-k100-rs-t829.htm?highlight=temp+sensor
theres a graph which corresponds to my memory/guestimate and makes your
4 ohms sound ominous
4Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed Apr 21, 2010 2:26 pm
ReneZ
ReneZ
He bigshrek, whereabouts are you? I've got a '84RT and a bit experience behind me. Happy to help.
4 Ohm is way to low for the sensor, could it have been 4kOhm?
Normally too much fuel comes from bad connectors in the coolingwater sensor line or the sensor itself gone bad. Perished rubber parts, although very bad for your engine running. Some more posibilities. What have you done so far??
Rene
BMW K100 - 1985 (0030029) Scotland wet spark plugs Rain
5Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed Apr 21, 2010 5:11 pm
bigshrek
hi rene
i will re-check the 4 ohms bit i stay in clydebank but the bikes at my work just down from anniesland iam almost positive its electrical its getting a good spark well at least until it floods i had a problem with the starter relay all it was doing was clicking so i earthed the brown wire and it will turn over and start now i dont think thats got anything to do with the wet plug sympton ive stripped out the air flow meter and all seams fine i have also renewed the throttle sensor. When i took the plug off the coolant sensor it was a bit green with corrosion will clean that up any help would be greatly appreciated
iain
6Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed Apr 21, 2010 5:34 pm
recently, I had got the same problem and it was the plug of the FI computer that didn't "click" correctly. The engine was flooding to the point that the gas was mixing with the oil in the crankcase
wet spark plugs Frog15wet spark plugs Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed Apr 21, 2010 5:40 pm
bigshrek
hi
i know it was fitted right i heard the click that was the first thing i checked ive had it before when it didnt start once cheers
iain
8Back to top Go down   wet spark plugs Empty Re: wet spark plugs Thu Apr 22, 2010 8:11 am
reg_K100RS
If the sensor is suspect
You could nip down to Maplins or RS, get a 4k7 pot for about a quid
(actually cheaper, just looked.-> min pot lin Code JM70M £ 0.80 in Maplins)
Solder two leads between the sweep and one outer track connection then
disconnect the plug and use the pot to replicate the sensor.
turn it up for cold ( 4k7), down for hot.
maybe just bunging a 1K resistor
across the pins might persuade the EFI
yer not chipping ice off the
bike wet spark plugs Icon_biggrin
wet spark plugs Arrow_up
9Back to top Go down   wet spark plugs Empty Re: wet spark plugs Thu Apr 22, 2010 2:25 pm
bigshrek
i have just checked the coolant sensor again and it works fine back to the drawing board wet spark plugs Confusedwet spark plugs Confusedwet spark plugs Confused
10Back to top Go down   wet spark plugs Empty Re: wet spark plugs Thu Apr 22, 2010 2:53 pm
ReneZ
ReneZ
Can you tell us how you checked it?
Rene
11Back to top Go down   wet spark plugs Empty Re: wet spark plugs Thu Apr 22, 2010 3:37 pm
bigshrek
took the sensor out and checked it with a multimeter got 3.5 kohms at normal temperature then heated a cup of water and it went down to 1.6 kohms
12Back to top Go down   wet spark plugs Empty Re: wet spark plugs Thu Apr 22, 2010 7:29 pm
ReneZ
ReneZ
OK, sounds good. Do you know the temperature of the water when you got the 1.6K? Does it follow more or less Bert's graph?
The amount of extra fuel you're getting makes me wonder if you have a short in the cable between the injectors and the ECU (they open when that happens).
Rene
13Back to top Go down   wet spark plugs Empty Re: wet spark plugs Fri Apr 23, 2010 12:56 pm
bigshrek
yes the diagram was spot on yes i thought of that will do a check on the loom next
14Back to top Go down   wet spark plugs Empty Re: wet spark plugs Fri Apr 23, 2010 3:01 pm
ReneZ
ReneZ
OK, let us know how you get on. Otherwise its easy enough to come over one (dry?) evening next week.
Rene
15Back to top Go down   wet spark plugs Empty Re: wet spark plugs Fri Apr 23, 2010 5:51 pm
Good on you ReneZ.
16Back to top Go down   wet spark plugs Empty Re: wet spark plugs Tue May 25, 2010 3:16 pm
bigshrek
At last problem solved it was all my fault due too lack of maintenance the choke was seized on what an idiot but hey ho you live and learn thanks for everybodys help............
17Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed May 26, 2010 2:13 am
Thanks for sharing that bigshrek, all too many don't admit what they did and then we don't all learn so we can think to ourselves "I mustn't do that" about whatever the issue is.
18Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed May 26, 2010 5:24 am
Don't start a topic about idiotic things we have done when working on our bikes over the years...it'd be a long one.
19Back to top Go down   wet spark plugs Empty Re: wet spark plugs Wed May 26, 2010 3:37 pm
ReneZ
ReneZ
Good one M8. You didn't call, so I thought you were doing OK. Have fun!
Rene
