1Back to top Go down   Starter trouble Empty Starter trouble Fri May 07, 2010 7:13 am
MarkR
Can anyone help me with some good drawings/technical info for the starter motor/sprag clutch on a '86 K100rs.
Any help would be greatly apreciated!
MarkR
2Back to top Go down   Starter trouble Empty Re: Starter trouble Fri May 07, 2010 11:08 am
If your sprag clutch is slipping, you can try to flush you engine.
If you don't want to go this way, this engine has to be taking off the bike in order to access it. (The clutch housing has to be removed).
Starter trouble 34
Starter trouble Frog15Starter trouble Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Starter trouble Empty Re: Starter trouble Fri May 07, 2010 3:22 pm
Hi MarkR,
Try draining the engine oil, fitting a new filter and refilling with premium quality diesel engine oil like Shell Rotella or Rimula and go for a really long hot ride. That should clean up the engine safely and should hopefully loosen off the sprag clutch. Try using the diesel oil for several oil changes to thoroughly clean it out, remember as our K clutch is outside the oil there is no worry about the effect of the oil on the clutch.
K-Bike
4Back to top Go down   Starter trouble Empty Re: Starter trouble Fri May 07, 2010 5:37 pm
MarkR
Thanks for the advice!
MarkR
