1Back to top Go down   Rear axle drive & drive shaft Empty Rear axle drive & drive shaft on Wed Jun 01, 2016 4:31 pm
AmaiaUSC
AmaiaUSC
Hi there !
So last Sunday my K break down after a great weekend motorcycling Crying or Very sad . The drive shaft spline are not anymore there and those of the rear axle are seriously damaged. So I decide to invest and I will like to change both (I think is the best option !). I am so happy with this bike that I couldn't let it down !
So, does somebody already been in this situation ? Where can buy the parts ? Any advice regarding used or new parts ?
I already contacted Moto-bins and Motoworks. No answer for the moment.
The parts OEM number :
Rear axle drive 33111450955
Drive shaft 26111241630
Thank's in advance !
https://www.bonnieandklyde.ch
2Back to top Go down   Rear axle drive & drive shaft Empty Re: Rear axle drive & drive shaft on Wed Jun 01, 2016 9:33 pm
You can repair the shaft by welding a new spline section on, Motobins have them. The drive is however not as easy, you would be best to find a good used drive. The splines can be repaired but it is expensive. There will be some engineering shops that have the facilities to repair it.
