1Back to top Go down   ignition issue Empty ignition issue Fri Jul 08, 2016 8:32 am
andyldean
andyldean
Hi all,
I have just stripped my K100 RT in the process of building a cafe racer.
Sent all the engine covers away for powder coat and set about the rebuild.
During the process I removed and replaced the crank sensor assembly.
now when i try to start the engine it doesnt start and i get a back fire like the timing is out.
I took pics of the sensor plate before I stripped, so I know I can be too far out, but could I be 180 deg out? the sensor plate only has 2 cutouts so could it be firing 180 deg out to the valve timing?
Thanks in advance
2Back to top Go down   ignition issue Empty Re: ignition issue Fri Jul 08, 2016 11:32 pm
andyldean
andyldean
Managed to solve this one after a lot of thought.
After study I couldnt see how the timing could be 180 deg out by crank sensor.
But I had managed to switch the LT wires on the coils so I suspect the coils were firing out of sync there. Once I swapped those all was good and fires first push of the button.
3Back to top Go down   ignition issue Empty Re: ignition issue Sat Jul 09, 2016 3:27 am
good solve andy
4Back to top Go down   ignition issue Empty Re: ignition issue Sat Jul 09, 2016 4:52 am
Good one Andy. More often than not its just something simple. ignition issue 112350
A good practice with the timing sensor plate is to scribe a mark across the edge before you take it out. Can'tgo wrong then.
 ignition issue Austra12    Fuel:  95 Octane
5Back to top Go down   ignition issue Empty Re: ignition issue Sun Jul 10, 2016 3:44 am
andyldean
andyldean
Yes I always take a couple of pics on my phone before I strip anything down.
Its a good reference point for a later problem.
Always find this forum a great place to solve problems as well  Smile
