1Back to top Go down   Ignition ecu unit Empty Ignition ecu unit Fri May 21, 2010 3:50 pm
badgerdid
badgerdid
Is the ignition unit, the one under the tank, the same on a k75 as on the k100 just with different cable connections on the plug?
or are they different
thanks
2Back to top Go down   Ignition ecu unit Empty Re: Ignition ecu unit Fri May 21, 2010 4:15 pm
The BMW OEM part numbers vary from model to model with some variation for specific markets too.
12 14 1 459 021 most K75
12 14 1 459 018 most K100
3Back to top Go down   Ignition ecu unit Empty Re: Ignition ecu unit Fri May 21, 2010 4:46 pm
The K75 being a 3 cylinders, you cannot use the ignition computer on a K100.
Ignition ecu unit Frog15Ignition ecu unit Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Ignition ecu unit Empty Re: Ignition ecu unit Fri May 21, 2010 5:10 pm
You could try, if the connection was the same, which it isn't, but it would run like a drunk, three-legged gypsy at a paired couples waltz!
