1Back to top Go down   New to this magical place Empty New to this magical place Fri Oct 28, 2016 10:53 am
xASmith88x
xASmith88x
Hey all,
Just joined the forum and I cant stop reading about restores and repairs.  I got my first K100 about a year ago and it was a silly mess, fairing all cracked and falling apart so I removed them and am in the process of a Franken'bike.
I purchased the bike to teach myself how to work the engine as i hear its a joy to. It is now ride-able and i commute regularly with it. but I feel like there is always something that needs to be fixed....suspicious hall effect sensor issue or MAF. Poor power, running super rich with sooty black spark plugs.
any tips/advice for working on it would be much appreciated but for now ive been reading my clymer book
Alex
2Back to top Go down   New to this magical place Empty Re: New to this magical place Fri Oct 28, 2016 7:57 pm
Brad-Man
Brad-Man
WelCome to the Knuthaus...
New to this magical place Usa-lo10
3Back to top Go down   New to this magical place Empty Re: New to this magical place Sat Oct 29, 2016 10:29 am
Hi Alex. WelKome to the forum. Glad to hear you are enjoying the K-Bike. They are a dream in all respects.
Best if you put a post up in the technical/repair section regarding your problem as many don't read the intros.
But to get you started, if all your sooty plugs are the same, then it'll be easy to track down.
  1. Could be the fuel pressure regulator (FPR). Check to see if you are getting a good flow on the return hose. Or, open the tank and listen for the gush as it returns. Little or no return means your FPR needs replacing.
  2. Fuel Injection Control Unit (FICU) could be getting wrong signals from one of the sensors like the Mass Air Flow (MAF) sensor or the temperature sensor, the later being more likely. If the sensor goes 'open circuit' due to corrosion (very common) then the FICU thinks its in start mode and its really very cold and so pump a shit load of fuel in. Pull the plug on the FICU and test Ω between pin #10 and #13. At ambient temp it should be ≈2.5kΩ. There are instructions on the Trouble shooting link off the Portal page.
 New to this magical place Austra12    Fuel:  95 Octane
4Back to top Go down   New to this magical place Empty Re: New to this magical place Mon Oct 31, 2016 10:48 am
Curley
Curley
New to this magical place 177912
New to this magical place Ir-log11New to this magical place Ir-log11New to this magical place Ir-log11New to this magical place Ir-log11New to this magical place Ir-log11
cheers  White K100RS 1991  cheers Red K1100LT SE 1995 cheers Green K75RT 1995 cheers Black K75s 1987  cheers
5Back to top Go down   New to this magical place Empty Re: New to this magical place Mon Oct 31, 2016 2:16 pm
Welcome, before you get too deep into HES or MAF issues do the simple stuff like checking the TB rubbers and crank case breather pipe for cracks. Good luck with it.
New to this magical place Ir-log1188....May contain nuts!New to this magical place Ir-log11
K75RTP - 1994
6Back to top Go down   New to this magical place Empty Re: New to this magical place Tue Nov 01, 2016 5:58 pm
Welcome Alex,
Post up a few details of what your bike was before you started the transformation (model, VIN, year etc.) - it'll help with diagnosis etc.
Nice place McLean VA - lived there for about 2 years (2008 - 2010) and my kids went to Franklin Sherman Elementary School. Happy memories! Unfortunately, I didn't discover K100's until after I returned home to the UK - there is some cracking riding on your doorstep.
Enjoy!
New to this magical place Uk-log10 New to this magical place Sco-lo15
                              Paul  New to this magical place 905546712
