1Back to top Go down   Tips for removing center stand? Empty Tips for removing center stand? Sun Aug 13, 2017 5:44 am
boostd4
boostd4
Trying to remove the center stand but having a hard time getting the bolts out.  I've got the right size hex bit but it just wants to strip - seems like the bolt it siezed.
Somebody told me to jam some valve grinding compound in there and it should help the bit catch/grab the hex hole better.  I'm going to try that but just looking for any other tips from people who have removed it before (to fit the wider K1100 stand, etc).
Thanks!
2Back to top Go down   Tips for removing center stand? Empty Re: Tips for removing center stand? Sun Aug 13, 2017 6:19 am
You need to heat the bolts, they are secured with Loctite.
3Back to top Go down   Tips for removing center stand? Empty Re: Tips for removing center stand? Sun Aug 13, 2017 8:21 pm
Use a good Allen wrench (like the one in the factory tool kit) and a cheater bar to get some leverage.
I've stripped my share of Allen heads on K bikes but never a center stand one.
4Back to top Go down   Tips for removing center stand? Empty Re: Tips for removing center stand? Sun Aug 13, 2017 8:28 pm
I struggled with mine but then a complete assembly came up from Sherlocks.....so WD40 in copious quantities and just unbolted the 4 bolts. It's still in my shed but needs welding.
