1Back to top Go down   Cluster removal led neutral light Empty Cluster removal led neutral light Sun Aug 27, 2017 5:00 am
timo27
timo27
Hi all, I found a circuit on here followed it over and over again but i try it and blow number 1 fuse.
What are you trying to accomplish? Guinness World Records will need documentation and witnesses for any of its categories, including fuse-blowing. Smile
Cluster removal led neutral light 44271
timo27
timo27
As per the title - ive removed the cluster and i'm trying to get an led working using four relays and i keep blowing the fuse in the number 1 slot, i was wondering if anyone had any circuit diagrams.
I make ready-to-use relay boards for CA $21.00 (basically the cost of parts) plus shipping
The circuit I use looks like this:
Cluster removal led neutral light Lh6aBbSTTg4vSUWj1MSOD87g-f_V5uaI_3hvtuRjRmCV3KpU_ekSdZjGd56LlVhi4wuqSS7TGVXTMNYY1tXWvpaP6CVGqj0xKGN8B-HGACLKaEMgrP_2afltYeJgoz5IJjuBBGREFhtiyZyOSFhuMPFQoD4pf7OZNl7apAVSexZT3BZlmGkzrO5-rZjvaEcZBeF4oLRpiUOrEZljzV7zDMbj_mVUIuBCjcOUt13dnxPpBzOex4-Mk9aG-OllMrGfF80jPx87utsJy3LgYyOSnqnh32Nqbeu1fHz1XVHrfjoWz2z8fCeM6zKjeqe989vCPur6HP2SvxqhnoeOVeurZNM_5TFVwnuPNLRXCqbgXKBfnEqYuCtn-6sBeFvVHxPmmk_qiLsYVSH2PMYQ_BGzyK_G3fJyTQCg61LXGljhoOz0U8KFdj5hVsiKGPe6VQ_ywFPMke5JqY0bJkB-VwAgl9r8ScX16SxbilRiZ7D6IMhJLfiGVzgzg7k15F075Gf1fnj7PVCT-buXmDQenP1byJ8VSa94y7MAtyIXNwV3fsTQnSl0B36A9L6uyyaij70nj4luX--sRSw5-DnJDKrIzoY5MbPCi2gBwo1h2SuYZyJaBofh7LkZwK980vdDR5wGRVAUKfOrMV5zxXihzUSOwG4fKrJWrNNMqrmI9G2oz2aTzw=w898-h844-no
timo27
timo27
Thanks for that i'm in the uk so postage might be sky high, i didn't have diodes in mine if thats what that those symbols are?
Postage is not sky high to Europe, just CA$8.00.  Yes, the diode is very important.  I show two in the schematic but only one is needed.  I layout and construct the board from the schematic and needed two different diode footprints, surface mount and through-hole.
As I mention in the post, I'm flexible with this product. I can sell just the PCB, or the parts as a DIY kit or completed and tested units, at different cheaper prices obviously.
