1Back to top Go down   A Gearbox/Driveshaft question Empty A Gearbox/Driveshaft question Mon Oct 09, 2017 4:46 pm
DeRodster
DeRodster
Hi,
 Just wondering is it necessary to remove the drive shaft before removing the gearbox.
Am just waiting for LONG bolts to allow gearbox slide back, but drive shaft is still connected
I really don't want to remove it it's not necessary
if it is necessary how the hell do I do it as the swing arm is off and I can't see a vise grip grabbing the end of the shaft
Ta
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   A Gearbox/Driveshaft question Empty Re: A Gearbox/Driveshaft question Mon Oct 09, 2017 5:49 pm
My RT as you know is Monolever, we didn't separate anything at all and moved the complete gearbox/swingarm/final drive/wheel unit back as a single assembly, separated the gearbox from the bell housing and rolled it back on the wheel and laid it down as a single unit. I don't think the Paralever differs in that regard but not sure.
As for the long bolts.......any correct threaded rod of same diameter and thread pitch will do that job for you.
We took it apart after we had the clutch and rear seal done for gearbox seals spline lube etc etc and reassembled it in its component form.
3Back to top Go down   A Gearbox/Driveshaft question Empty Re: A Gearbox/Driveshaft question Mon Oct 09, 2017 6:07 pm
No, you do not need to remove the drive shaft from the back of the transmission.
