1Back to top Go down   Stripping the Tank Empty Stripping the Tank on Fri Oct 27, 2017 7:20 am
DBRMN
DBRMN
Hey guys,
I need to strip the paint of my tank before I paint it and was just wondering whether or not to take the BMW badges off of just put masking tape over them? I think they are stuck on so if I took them off what kind of glue would I have to use to put them back on?
Thanks,
DBRMN
https://www.gofundme.com/manage/helping-fund-my-motorbike-projec
2Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Fri Oct 27, 2017 7:55 am
BobT
BobT
They are stuck on with a neoprene based glue. Acetone (nail varnish remover) gets the old glue off, but the badges are quite thin and are easily damaged. New ones are available for very little money on ebay.
3Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Fri Oct 27, 2017 8:02 am
DBRMN
DBRMN
@BobT wrote:They are stuck on with a neoprene based glue. Acetone (nail varnish remover) gets the old glue off, but the badges are quite thin and are easily damaged. New ones are available for very little money on ebay.
So would you advise keeping them on to paint but just cover them? or get them off even if I damage them and buy new ones?
4Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Fri Oct 27, 2017 8:55 am
BobT
BobT
You need to do what you feel comfortable with. I would order some new ones, measure the diameter to get the correct size, and take them off. If you try and leave them on then the final job is never going to be perfect, and you would probably hate it if you had done all that work and it was not quite correct.
5Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Fri Oct 27, 2017 9:55 am
Use some dental floss under them that will get them off without damage and then double sided tape (automotive stuff) to stick them back on
If they are a bit damaged just peel them off but you will never get a paint job worth having if you mask them.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
6Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Fri Oct 27, 2017 11:06 am
The badge diameter is 70mm and BMW has doubled the price in the past three years to nearly $30US each. They are being sold on eBay for much less as 70mm wheel badges for BMW automobiles.
7Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Fri Oct 27, 2017 11:50 am
DBRMN
DBRMN
@RicK G wrote:Use some dental floss under them that will get them off without damage and then double sided tape (automotive stuff) to stick them back on
Yeah I read about that method I'll probably go with that let you all know how it goes! if it goes wrong I don't care about the paint because I'm doing a new paint job anyway or the badge as I can buy one so its not the end of the world. Thanks
8Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Sat Oct 28, 2017 9:51 pm
AndrewP
AndrewP
Hi Rick,
If you warm the emblem up with a hairdryer then use the dental floss or some fine wire will do the job they come off very easily. You definitely want to remove them.
They are pretty reasonable to buy new but I would save them if in good nick.
9Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Sun Oct 29, 2017 6:47 am
DBRMN
DBRMN
Update:
Used boiling water and a sponge to water board the emblems which seemed to work, but they were already beat up so i'll probably buy a new set.
10Back to top Go down   Stripping the Tank Empty Re: Stripping the Tank on Mon Oct 30, 2017 6:05 pm
Motorbike Mike
Motorbike Mike
@DBRMN wrote:Update:
Used boiling water and a sponge to water board the emblems which seemed t work
That's how they'd remove those badges in Guantanamo Bay! Laughing
