George_Pap
George_Pap
Hey community. Ι need  to remove the rear swingarm on my early 1985 K100RT  in order to check and replace my non functioning Gpi Sensor
Bike has already removed the rear fender-plate holder so i need to know the correct steps to do the disassembly.
I m describing so if something's wrong please advise:
1. Remove Rear brake caliper
2. Remove Speed sensor
3. Remove wheel ( i' m also replacing Rotor with a Brembo series Oro and proper calipers )
4. Remove final drive ( 4 allen bolts)?
Do i need to bleed the lubricant of the final drive shaft before that?
4. Remove left footpeg baseplate and the big hex nut and corresponding allen bolt
5. Remove the round plate from right side ( three allen + one in the center )
6. Detach Clutch cable
7. Pull back the swingarm.
Lubricants needed:
1. Lithium White Grease for the spline
2. Lubricant  (Type?) for the rear drive shaft
3. brake fluid for bleeding due to calipers replacement.
Anything missing? Its my first time and due to weekend i need to be sure that i m not missing anything
Thank you .
Swingarm Disassembly & Proper lubrication Img_2013
Swingarm Disassembly & Proper lubrication Img_2014
K100RT (Early 1985 -nonABS)
you may find it easier to remove the rear wheel first
just to access the caliper out of its mounts , but not necessarily most important
don't forget to support the rear swingarm - rear drive unit as you remove the shock absorber before the rear drive ,  and withdraw the drive shaft
good luck
George_Pap
George_Pap
charlie99 wrote:you may find it easier to remove the rear wheel first
good luck
George_Pap
George_Pap
good luck
Thanks!
There is oil in the final drive, drain it because otherwise it will leak all over the place. Its only about 350ml or something like that. There shouldn't be oil in the drive shaft itself or inside the swing arm but sometimes if the seal at the back of the gear box has a little leak it can get oil in there. Mine was but the oil also preserves the shaft.
You can leave the speed sensor in and just disconnect it from the loom. One less place for oil to leak from.
Chances are the rubber boot that goes from the swing arm to the gear box will be split. So I would have a new one for that.
The gear position indicator also uses a gasket. In my experience a new switch and gasket is the way to go.
Grease to be used is Staburags or Honda. It doesn't take much but good to get it right.
The screw on the brake disc may be hard to get out, get that off after you take the wheel off as you could end up drilling it out. All it does is keep the disc in place while the wheel is off. The wheel bolts are what hold the disc for braking.
Be prepared for two things to go seriously wrong:
1. The rear disc bolts round off (they're stuck in with red Loctite). Recovery procedure is to drill the heads off, then remove the remaining studs by either filing a flat on either side until you can get a 6mm or 7mm spanner on, or just grip the studs with a mole wrench (vise grip). I'd go for the filing first.
2. The heads snap off the GPI retaining bolts. They're only 4mm set screws and are probably pretty rusted by now. If they come out clean, replace them with 4mm allen bolts and lots of copperslip or similar. If they snap, you're going to hate me forever because it's a gearbox off, strip and specialist removal. There isn't the room in there to drill them out and replace with 5mm bolts; the originals have to come out. It might even be cheaper to get a s/h gearbox shipped in (minus the GPI because you don't want the same problem).
George_Pap
George_Pap
Thank you both on your advises , this is why I posted prior dismantling. Smile
What's the type of oil (300-350ml) inside the final drive ?
Also a regular white , lithium transmission grease wouldn't be proper?
Dai the GPI was removed already once 2 months ago so I expect easy removal.
As for the rear rotor bolts guess you mean the two extra bolts besides the bolts of the wheel?
These really frightened me cause I read most users having problems with these
Sent from Topic'it App
The two bolts holding the rotor do frighten simply because they will likely be seized and can be extremely hard to get out. Been there.
Final drive oil is 80W90 but there also seems to be a higher spec up to 140W. I use 80W90 and change both final drive and gearbox at the same time as they use the same oil. Final drive is up to the bottom of the threads on the filler plug. You need a little over 1 litre for both. I do engine oil and final drive and gearbox at the same time so none are in too long.
For gearbox this is your dipstick depth if you don't have the C spanner in your toolkit. I have a screwdriver in my kit with a mark at 116mm for checking while away from base. DONT use a screwdriver with loose or reversible shafts.....if it comes out it ends up in your gearbox and you wont get it out. I don't have a use for the C spanner as I don't have the original shocks. You can always cut one out of plastic.
Swingarm Disassembly & Proper lubrication C_span10
George_Pap
George_Pap
Thank you!
Dai: Thanks.  I'd seen Brit references to a mole wrench before but never had any idea that it meant Vise-Grips.
SOMETIMES heating the rear rotor bolts very hot with a torch (a real one, not a flashlight) will make it possible to free the rear rotor bolts so that the heads don't strip. But that doesn't always work.
If I remember, I usually try to remove the rear rotor while the FD is still on the bike and the bike is in gear. Otherwise, on the workbench you will need leverage to keep the final drive from turning when you remove the leftover bolt studs. I reinstall a couple of the lug bolts and then lever those with a bar to keep the final drive from turning:
Swingarm Disassembly & Proper lubrication Rearro10
I've never had an issue with the GPI switch bolts.
George_Pap
George_Pap
duck wrote:Dai: Thanks.  I'd seen Brit references to a mole wrench before but never had any idea that it meant Vise-Grips.
cheers cheers cheers
George_Pap
George_Pap
92KK 84WW Olaf wrote:DONT use a screwdriver with loose or reversible shafts...
i still have a spanner of my rear shock. Its a WP one and its span key looks exactly like that!
You don't need to remove the disc from the drive to do a lube job.
Don't let the swing arm drop when the shock is detatched , the drop will damage the rubber boot to the gearbox.
If the left swing arm pivot bolt is difficult to remove try to get in behind the case and clean the thread, it will be covered in grit. When you replace the pivots leave heaps of grease there to protect the thread for future removal.
RicK G wrote:You don't need to remove the disc from the drive to do a lube job.
+1.  The rear rotor only needs to be removed if you need to replace it or swap final drives.
George_Pap
George_Pap
The reason i want to remove the rear disc is to replace it with a brand new Brembo one. The current disc is worn out and shows some cracks (both sides) along its surface.
As for the swing arm drop.. I hope i didnt do damage already when i removed the rear shock to powdercoat its spring. I removed the spring with the rear wheel / tire on though.
George_Pap
George_Pap
The one piece of info i'm still missing is the grease type for the spline.
In the local market i can find Lithium white grease and Moly base ( which most of the suppliers here suggest
What should i prefer?
Are there any special characteristics i need to pay attention to or to avoid?
The issue with letting the swing arm drop too far is that it MAY cause the swing arm boot to pop off.  This doesn't always happen and isn't the end of the world because all you need to do in that case is pop it back on.
You can tell if that boot is attached properly by pulling the swing arm back slightly (with the pivots removed) and letting it go  If the boot as still attached properly then it will cause the swing arm to move back towards the transmission.  I always to this when putting the swing arm back on to ensure that the boot is seated properly.
Check the boot it may have a cut about 10 - 15mm long. I just clean the cut with acetone and use super glue and have never had one fail yet, in 10 years.
George_Pap
George_Pap
allright! Wil do the check! Thank you all!
George_Pap wrote:The one piece of info i'm still missing is the grease type for the spline.
It's strange you should be missing that one piece of info because it is one of the most discussed topics on the Internet among BMW owners that ride shaft-driven bikes. scratch
Pay attention to be sure the lubricant is stiff like paste rather than soft like grease. Only a relatively thin covering is used on splines. I brush it onto clean splines with a toothbrush. I've done the transmission input splines twice, the driveshaft and final drive input splines five times and there is still some remaining in a container similar in size to a 35mm film canister that contained 30 grams of Staburags NBU 30 PTM.
Avoid applying it with a cake decorator. Laughing  Excess lube wastes money and also can be slung onto the clutch disc if you over-do it on the transmission input side.
glennpm
glennpm
I don't think that stuff's available any more... is it?
George - in Europe it's probably easier to get hold of Castrol Optimol.
Correct. The guy who owned GD retired and closed up shop a couple of years ago.
George_Pap
George_Pap
Really appreciated all the help.
Never thought that getting the correct lubricant would be such a headache!
Got down to this grease . Krafft - extreme pressure lithium grease with molibdenium disulfide. From a Moto lubricants store. It's feel in my fingers regarding thickness is like a toothpaste .
I m ordering also the Castrol molylube from motoworks but until arrival I ll be putting this one tomorrow.
Weekend provides me the only time luxury to do some work on K. So I gotta move on Smile
Swingarm Disassembly & Proper lubrication 20180420
Swingarm Disassembly & Proper lubrication 20180421
Swingarm Disassembly & Proper lubrication 20180422
Adding Moly to the transmission gear oil helps smooth out shifting.  It take several hundred miles to work its way in but after that the difference in shifting is noticeable.
glennpm
glennpm
Hi,
I see that duck replied already but here is mine, "Yeah, I just checked Snowbum’s site and they went out of business two years ago. Lots of good information here on other spline lubes though"
http://bmwmotorcycletech.info/chemicalsetc.htm
Swingarm Disassembly & Proper lubrication Cleardot
Glenn
nobbylon
nobbylon
I’ve always used Optimol on small clutch splines. White was the preferred but I ran out and have a tube of silver. Higher temp stuff I think. Used it on the K’s rear splines and in summer will do the clutch and re inspect the drive once more. I have some LM47 which I’ve used for years on R rear splines and I suppose this would be fine on the rear drive of K’s too.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
This is what I have used on splines ever since me and splines became acquainted
http://www.itwpf.com.au/molybond-lubricants/ga50/
George_Pap
George_Pap
Works day I
Rear disassembly was smooth . No problem with any of the bolts Smile Boot was in great shape.
Rear disc replacement also smooth, a couple of minutes heating of the two Allen bolts helped removing them without stripping.
Also replaced front brake main cylinder by using a 13mm pump repair kit from Motoworks. Bleeded also the front brake system ok.
Here s is the spline so any feedback from your experience on its condition appreciated. To my eyes looks ok , ok found, some rust muck inside but after cleaning splines look fine.
Before cleaning
Swingarm Disassembly & Proper lubrication 20180423
After
Swingarm Disassembly & Proper lubrication 20180424
Swingarm Disassembly & Proper lubrication 20180425
Problems occured:
Throttle after opening became some kind of rough in feel, like teeth rubbing , no linear feeling in throttle turning .
Put some grease in but no special improvement. Opening throttle feels ....clicky ?! Steppy? Any suggestions?
Replaced also the GPI sensor. Still no luck. Ok I was getting some 1 if I was keep pressing the gear lever down with my foot. Otherwise blank .
2 sensors in a row with the same behaviour. Ok, both were used ones. Instrument checked LCD works fine , green light too..
Dead end.
George_Pa wrote:Throttle after opening became some kind of rough in feel, like teeth rubbing , no linear feeling in throttle turning .
Check the 'teeth' at the end of the throttle twist tube and also on the cam disc (gear and chain - attached to the upper end of the throttle cable) which actuates the throttle. These can become worn and will feel 'steppy' or notchy and intermittent even with a good smear of grease on them. The only remedy is replacement if they're worn. Keep in mind the single mark which shows where alignment takes place between both the gear and the throttle tube end.
Your GPI issue may be due to a bad connector.
Here's my page on GPI stuff:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/gpi/gpi.htm
The spline on the drive is fine what is the condition of the spline inside the shaft. I would expect it to be good but I have seen bad shafts and good drives before.
George_Pap
George_Pap
This weekend's works performed:
Original Bosch new fuel pump , vibration ring, pump base replaced.
Fuel sender (early model) replaced with a used one.
Front brake pump 13mm replaced due to leaking on the front brake lever.
Used GPI sensor replaced , still no luck, I get random numbers at random time
Rear disc rotor replaced with a Brembo series Oro and corresponding pads
Swing arm disassembled and lubed the spline , new valvoline 80/90 fluid in the final drive shaft.
Partial fairing back in place , missing the two lower parts that are being painted .
At this point I really feel the need to thank you all for your precious advise and help . Without this forum none of the above tasks could take place.
I took my RT to work yesterday and tried to put as more kms to it as possible . Did about 140 km and besides the none working GPI and fuel lamp everything worked like a charm.
Also had problem strarting it once ( of approximately 10-12 starts yesterday ) . Took a lot of starter spinning to get the engine on.
I ll be monitoring this behaviour.
I recall that one thing that s left not swapped since the ressurection try is the air filter . Mechanic that inspected the bike initially said it was ok.
Could this cause starting random starting failure ?
Also there are are 4 flat screws on the injection bodies. What do the do?
I set the idle running to 1000 - 1100 rpm when cold.
Any suggestions?
What do you read in the different gear and neutral?
The slotted brass screws is for syncronizing the amount of air to each
cylinder at idle...........vacume gauges is used to carry out this task.
George_Pap
George_Pap
Thanks Inge !
Blank in Neutral. No green light ofcourse.
When kicking first gear in i get 1 on the lcd but after lifting my foot from the shifter blank again. From time to time i get 1 on lcd for some seconds then blank.
Never seen 2 on LCD
I get 3 sometimes. Randomly. In 3rd gear
In 4th gear i get the number 5 on LCD. Steady most of the time. Not always, but most of the time.
Never had proper reading on 5th. I just get blank.
As the replacement sensor was from a newer model with black plug and round pins i have the cables directly connected and sealed to the female pins of the instrument side.
As for the 4 screws i m affraid that the mechanic messed with them as i recall. Totally in blind. Idle rev is too high when bike warm. 1200 rpm. And when i lower the idle rev screw (hexnut in the middle of the injectors body) i get very poor idle rev when cold.
Is there a way/symptom to identify the correct air amount?
Not easy to figure out any from your gear position signals, sounds like the
switch is out of position.
A easy test to check out all the wiring in both directions:
Disconnect the switch at the connector above the gearbox.
Leave the bike in neutral.
At the switch end check the continuity between the brown wire and all
three of the yellow wires....you should have continuity between all of them.
At the harness side connect all four wires together.
With ignition on you should read 0 in the display and the neutral light on.
About syncing the TB's...you can make a simple DIY tool out of some meters
of vinyl tubes, ATF and some plastic fittings.
Tubes and fittings you find in a aquarium shop...also by four valves to
restrict the air flow.
Search youtube for DIY carburator synchronizer tool, much easier to see
it live on a movie than explain it in bad English.
To be used only on idle!
George_Pap
George_Pap
I did the GPI check exactly as you describe when sensor was visible with the swing arm removed.
I don't get continuity with brown and other 3 cable combinations.
The test from connector to the instrument was successful though.
What about the position? The cut of the cylinder that comes out of the gearbox was aligned horizontally as the corresponding cut on the switch female side.
Another clue maybe worth to mention is that the left screw that holds the sensor in place is stripped but even with pressure on the sensor with my hand the behaviour was the same.
Then it's obviously here the problem is....if the gearbox was in neutral.
George_Pap
George_Pap
Yes it was for sure. It's just sounds very suspicious to me how can two sensors in a row be faulty Sad
If the readout was identical for both switches.....
Switch out of position.
Damaged end of the selector drum......which is hard to believe.
It's a fact that you should have connection between all four
wires when the gearbox is in neutral.
George_Pap
George_Pap
Selector drum? I guess you mean the pin that drives the GPI switch? The one in the gearbox?
When swing arm was disassembled I changed all gears to check it if it's turning. And it was changing angles as it should...
What I have in mind is the half moon on the end of the drum which
engages with the switch....it should be a rather tight fit without any play.
But I would rather guess that it's the broken screw that is the reason
to the problem...and it lets the switch out of position.
In post 21 in this thread it's a link where you can see the switch/selector drum
position in the different gears....which can help you when measuring and
checking out the old switch.
George_Pap
George_Pap
Inge K. wrote:What I have in mind is the half moon on the end of the drum which
thank you. I'll keep researching .. Waiting and hoping for the day that the green light will come on Smile
