1Back to top Go down   Water Temp Sensor  Empty Water Temp Sensor Wed May 16, 2018 10:03 am
Trapper
Trapper
Hi all,
Any idea where I can get a Water temperature sensor BMW Part number 62161459270 (or equivalent) for my BMW K1 water/oil pump. dimensions are H 25mm x W 10mm, thread depth 10mm.
Very best
Trapper
K1 Red & Yellow 1990 111.000 Kms & BMW K1 Red & Yellow 1991 22.000 Kms
 Water Temp Sensor  Ir-log10
2Back to top Go down   Water Temp Sensor  Empty Re: Water Temp Sensor Wed May 16, 2018 10:32 am
3Back to top Go down   Water Temp Sensor  Empty Re: Water Temp Sensor Wed May 16, 2018 10:37 am
Is that the one behind the radiator, if so is it same as 84 K100? Or the one for the temp gauge? If one for gauge and same as K1100 Will probably has it...!
Just checked the later post, the sensor I have is for 2v, no good to you.
Last edited by 92KK 84WW Olaf on Wed May 16, 2018 12:02 pm; edited 1 time in total
4Back to top Go down   Water Temp Sensor  Empty Re: Water Temp Sensor Wed May 16, 2018 11:49 am
td5
td5
Water Temp Sensor  K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
5Back to top Go down   Water Temp Sensor  Empty Water Temperature Sensor Sun May 20, 2018 7:33 am
markysimon
markysimon
Yes, MotorWorks definitely sell them, but can anyone tell be what the washer it uses is made of? The (Haynes) manual simply refers to it as a 'seal' but when I removed my sensor after the cooling system overheated – the fan proved to be broken – it didn't have one and now I'm putting it back, I can't figure out what the washer should be? Shocked In the photo on the MotorWorks website it looks like it might be alloy, but that seems unlikely.
6Back to top Go down   Water Temp Sensor  Empty Re: Water Temp Sensor Sun May 20, 2018 7:41 am
It's alloy and comes with a new sensor. I know 'coz I bought a new sensor two weeks ago Very Happy
7Back to top Go down   Water Temp Sensor  Empty Water Temperature Sensor Sun May 20, 2018 7:53 am
markysimon
markysimon
Dai wrote:It's alloy and comes with a new sensor. I know 'coz I bought a new sensor two weeks ago Very Happy
Ah, thanks for that: I'm sticking with my 'old' sensor so now I'll just have to find an alloy washer! Easier said than done here in rural Wales!  Crying or Very sad
8Back to top Go down   Water Temp Sensor  Empty Re: Water Temp Sensor Sun May 20, 2018 8:48 am
There's another forum member just south of you in Dolyhir, at the foot of Hergest Ridge. Blacksmith Adam is no longer a blacksmith but a teacher, which is why he hasn't had time to login here for quite a while.
