1Back to top Go down    Side stand retract K1100 onto K100 on Wed Jun 20, 2018 2:13 am
Tesla13BMW
Tesla13BMW
Because my 86 K100 stands seem to be bent up I took advice and procured a K1100 stand.
As seen in the photos (K1100 on top) the sidestand clutch retract mechanisms are different and I did not receive the connector rod for the K1100 stand.
What do people suggest to have the K1100 stand with the retract mechanism working. Do I just swap over the entire retract mechanism off the K100 stand?
Brisbane, Australia. '86 K100RS
2Back to top Go down    Re: Side stand retract K1100 onto K100 on Wed Jun 20, 2018 3:46 am
Chocolate
Chocolate
@Tesla13BMW wrote: just swap over the entire retract mechanism off the K100 stand?
Just swap the mechanisms as seen on your picture, I swapped the side stand too. I have a mainstand from a K1100 on a K75.
If I pull the clutch the sidestand goes up, as it should.
3Back to top Go down    Re: Side stand retract K1100 onto K100 on Wed Jun 20, 2018 7:03 am
OTOH you can always junk the retraction mechanism. One more thing to go wrong and one more thing to make the clutch heavy.
4Back to top Go down    Re: Side stand retract K1100 onto K100 on Wed Jun 20, 2018 8:02 am
You can do a direct swap. The K1100 retraction mechanism actuates a switch; the k100 mechanism physically links the clutch to the sidestand. Both are safety mechanisms and defeating them increases risk of an upset. Although you will hear opinions from both sides (I prefer the retraction mechanism), the decision is yours based on your appetite for risk.
2011 Moto Guzzi V7 Racer
5Back to top Go down    Re: Side stand retract K1100 onto K100 on Wed Jun 20, 2018 11:19 am
My K100LT has the retract mechanism. Its useful and when you pull on the clutch you immediately know its down and can either kick it up or let the clutch lever do it. I was never tempted to disconnect it.
My K1100LT has the switch which is just as useful.
My K100RT had the auto retract which I disconnected and yes I have occasionally taken off with the side stand down.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 87,980 miles
1983 K100RS 0011175 Fricka 29,000 miles Damn K Pox
6Back to top Go down    Re: Side stand retract K1100 onto K100 on Wed Jun 20, 2018 8:14 pm
Tesla13BMW
Tesla13BMW
Thanks all for the info.
Robmack that explains a lot. I thought I was missing parts but you saying it actuates a switch makes it obvious now!
I like the auto retract on pulling the clutch and will try and keep it but do realise it does "load up" the clutch cable.
7Back to top Go down    Re: Side stand retract K1100 onto K100 on Thu Jun 21, 2018 10:13 am
It only loads the clutch cable when the stand is down. Proper adjustment and lubrication minimizes the loading.
1994 K75S
1992 K100RS
8Back to top Go down    Re: Side stand retract K1100 onto K100 on Thu Jun 21, 2018 5:34 pm
I love the mechanical retract, and prefer it's simplicity over the potentially troublesome switch. As seven five stated as soon as you feel resistance flick it up with your foot. When I first got mine, I used to love people reactions when they warned me that my stand was down. Only to be surprised as the stand popped up as I went to engage gear.
I very rarely let it self retract, it's pretty well automatic to flick it up.
