1Back to top Go down   Another spline question Empty Another spline question Mon Jun 10, 2019 5:45 pm
Heresy23
Heresy23
Another spline question 746b4710
Another spline question 381ea710Ok here’s my final drive splines..they look good .....2 things...can u use gasoline to clean before I lube? And all the gunk that’s in the housing , coups I just squirt degreaser in there? I don’t wanna ruin any seals ..and the red stuff is obviously a sealent ...should I leave it there?....I’m doing this now ....thanks
Another spline question 84f19f10
Another spline question 03c12310
Another spline question 34cc9710
Better pics
85’k100 RT 73k
2Back to top Go down   Another spline question Empty Re: Another spline question Mon Jun 10, 2019 6:01 pm
volador
volador
Gasoline, kerosene (is best), denatured alcohol, brake cleaner, a good degreaser all work
It can't hurt to leave the sealant to keep out water or apply a new bead
Be on the look out for a another 16 tooth drive shaft
3Back to top Go down   Another spline question Empty Re: Another spline question Mon Jun 10, 2019 6:30 pm
Heresy23
Heresy23
Thanks...I decided not to pull out the drive shaft and lube it ....next tire change...I don’t wanna go thru the hassle of pulling out and re-aligning....I feel like since it’s my first time I might have a issue and I was told it’s probably fine anyways
volador wrote:Gasoline, kerosene (is best), denatured alcohol, brake cleaner, a good degreaser all work
85’k100 RT 73k
4Back to top Go down   Another spline question Empty Re: Another spline question Mon Jun 10, 2019 7:50 pm
volador wrote:Be on the look out for a another 16 tooth drive shaft
Why? They last much, much longer than the Z20 ones.
5Back to top Go down   Another spline question Empty Re: Another spline question Mon Jun 10, 2019 8:27 pm
volador
volador
Good to have a spare on hand
6Back to top Go down   Another spline question Empty Re: Another spline question Thu Jun 13, 2019 7:54 am
GF Wollongong
GF Wollongong
While we're talking splines ...
Has anyone found a use for a worn drive shaft? Got one in the garage and can't bring myself to throw it out ... can't think what to use it for?
Hoarder
7Back to top Go down   Another spline question Empty Re: Another spline question Thu Jun 13, 2019 8:05 am
You can renew the splines. Cut off the old ones and weld on a new set from Motobins.
8Back to top Go down   Another spline question Empty Re: Another spline question Thu Jun 13, 2019 10:19 am
I have heard of people replacing the u-joint.  I have found the part number in the past and they are available for about $28.  Any shop that does drive shafts should be able to do the machine work.
