1 Is this a TPS issue? Tue Feb 22, 2011 12:10 am
kevin_stevens
Haven't found this particular problem in a quick search through this section, so here we go...
Have a new-to-me 1987 K100RS, 35K miles in extremely pristine condition. The only glitch I can find with it is that when coming to a normal-to-brisk stop, say at an unexpected yellow light, I'll downshift through the gears, and at about 15mph when I pull the clutch in and finish rolling off the throttle, the revs will dip below idle (steady 1000rpm) by a couple of hundred, and either flash the charge light momentarily or actually have the engine die before it can come back up to idle speed. There is a tendency to do this on any load-to-idle situation, but it isn't typically bad enough to cause more than a slight dip below idle except as described above.
Doesn't do this on startup (steady 1000rpm idle hot or cold as mentioned). Doesn't do it on neutral rev/dropback. There doesn't seem to be a negative throttle slack - i.e. if the bike is idling in neutral, and I roll the throttle forcibly closed, the idle doesn't change.
The bike does have a Luftmeister exhaust, but that's the only relevant mod I know of (and that's up for trade in the For Sale section, btw).
Is this a TPS issue, or something else well-known, or does it need more diagnosis?
Tx all!
KeS
Tx all!
KeS
