1 A quick ABS Warning Relay question. Mon Mar 30, 2020 6:37 pm
Bonzo
I'm trying to ascertain whether I have a duff abs warning relay. Its a small blue relay with part No: 61311459675.
I have the relay out on the table and I ran my meter over the pins and there was a reading between terminals 30 and 87 (2.0 ohms). My brother says there shouldn't be a reading there and thinks the switch has welded together. I opened it up and can confirm it isn't welded and can be easily prised apart with a small screwdriver. When the contacts are apart - there is no reading/bleep.
Q. Should there be a reading between these two pins?
