1Back to top Go down   Total Rear Travel on K100rs Empty Total Rear Travel on K100rs Fri Apr 24, 2020 12:26 pm
jnclem
jnclem
I'm sure this is on here somewhere, but after searching I haven't found it. Do you guys know the total rear travel on an '89 K100RS? I'm installing a new shock and want to set up the preload.
I'm assume about a 25% of total travel initial preload. I did see one post that said 1.25 to 1.5 inches, but I'm not sure which K they were discussing there.
I found some old specs that suggested 4.3" of travel, not sure if that was accurate either.
Anyway, wanted to check here before I work on it. The shock is a TFX from the Beemer Shop. It will have adjustable preload and rebound dampening.
2Back to top Go down   Total Rear Travel on K100rs Empty Re: Total Rear Travel on K100rs Fri Apr 24, 2020 1:57 pm
Monolever K bikes have 110mm or 4.3" of suspension travel, according to the RSD repair manual I have, and also the www.motorcyclespecs.co.za I use frequently for Beemer stuff.
What you'll have with that TFX is adjustable preload and damping, as dampening means to moisten something.
3Back to top Go down   Total Rear Travel on K100rs Empty Re: Total Rear Travel on K100rs Fri Apr 24, 2020 5:06 pm
jnclem
jnclem
Two Wheels Better wrote:Monolever K bikes have 110mm or 4.3" of suspension travel, according to the RSD repair manual I have, and also the www.motorcyclespecs.co.za I use frequently for Beemer stuff.
Correct. Good catch and thanks for the info.
