1 K75 issue Tue Mar 03, 2020 12:53 am
MikeisonTV
So I have a friend who dropped off her k75 café conversion. It fires no problem and will idle though it sounds weak compared to my K100 (also a cafe).
The issue is as soon as I touch the throttle it will die.
Having combed through mine with you guys help over the years, I started with the obvious, fuel pump and fuel filter. I figured the fastest way to rule these out would be to swap hers with my tank. I did, same thing. That rules out the fuel pump, filter, and lines inside the tank. There aren’t any vacuum leaks (no cracks in the hose or vacuum caps.
I just pulled the injectors to test them next.
