1Back to top Go down   Petrol tank gasket Empty Petrol tank gasket Fri Jul 31, 2020 12:52 pm
gabriel
Hi
I noticed my 1983 k100 doesn’t have the u shaped foam? Gasket which is located under the petrol tank.
I decided to purchase and install one today. Unfortunately the petrol tank is a much tighter fit on the frame and it is difficult to push the tank forward like I used to.
Did all k100 motorcycles have the foam u shaped gasket?
Gabriel
;BMW; 1984 BMW k100..frame number 6228?
1992 BMW K75s
2Back to top Go down   Petrol tank gasket Empty Re: Petrol tank gasket Fri Jul 31, 2020 5:45 pm
AFAIK, yes. Wriggle the bugger - it goes in eventually. Just make sure the foam piece is properly seated behing the coolant filler cap.
3Back to top Go down   Petrol tank gasket Empty Re: Petrol tank gasket Fri Jul 31, 2020 9:32 pm
moriarti
moriarti
Should your tank have the insolation heat pads fitted it will be very tight
doublesided carpet tape is good to hold it in place and a tie wrap on both ends.
silicon spray on the rubber helps as well Very Happy
4Back to top Go down   Petrol tank gasket Empty Re: Petrol tank gasket Mon Aug 17, 2020 9:26 pm
gabriel
Hi
Is it possible for anyone to post a photo of the foam gasket installed?
Gabriel
1992 BMW K75s
5Back to top Go down   Petrol tank gasket Empty Re: Petrol tank gasket Tue Aug 18, 2020 2:26 am
Suzi Q
Suzi Q
My 1984 naked K100 didn't have one when I bought it in '87. I thought that the heat control was only needed on faired models. Pretty sure about that.
6Back to top Go down   Petrol tank gasket Empty Re: Petrol tank gasket Tue Aug 18, 2020 7:56 am
Chris is right. If yours is a naked bike and it has the heatshield under the tank, you can peel it off with no adverse running effects. Otherwise, see this and ignore the burnt bits:
http://www.simpilot.net/~sc/brick3/87b.png
