1 K1100LT ABS Issue Electrical Wed Aug 05, 2020 7:18 pm
It seemed quite simple.
Battery flat on Saturday......ok took it out and charged it up.....put it back in ABS pump kicks in [ABS 2].
Ok, so far so good, took out relay.......bike doesn't run without the relay....battery ok next day.
Monday......put the relay in, go for a run, park bike, take out ABS relay....gee the ABS pump is running.....so its getting power from some other source....
Electrics on this K are all unmolested, only changes made are the fitting of air horns and they are on the original horn connectors and all good and trailer wiring all done at the rear indicators and connector block.
For the moment my thought is to disconnect the ABS unit until I can get at the problem but this does not look possible.
Question and help needed is what wires should I be looking at or is there a connector I can unplug.
1971 Yamaha 125 YAS-1
