1 temp gauge wiring Fri 23 Apr 2010 - 11:23
badgerdid
Im going to fit my own temp gauge and wire it to the special equipment plug, i presume this is the best place to wire it too?
looking at the colour wiring diagram in the download section,
Am i right in thinking -
the light+ will go to the yellow wire, the other side will go to earth
The plus live will go to the green and black wire, i think this is a ignition switched live
There will be an earth again to the frame
The sender will then go to the signal terminal on the gauge.
can someone confirm i have the right colours to the right connections, i wont be using the proper bmw plug so will be coming off the wires direct.
thanks
thanks
